AH FabricationsEM Tuning
    May 2010
    scunthorpe
    35
    Has anyone performed a boost leak test on a 2.0t fsi before.
    Hello as above after my list of faults and before i order my new DV i was going to do a boost leak test to see if i have any more leaks. I have read up that on the 1.8T u remove the PCV return hose is there anything like this on the 2.0T to remove.
    Cheers Slim
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    i had the garage do mine
    why dont you just remove and check if its ****ed
    May 2010
    scunthorpe
    35
    Just want to check to make sure nothing else is nackerd.
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    As above, this never really got answered.
    Anybody got any simple step by step advice on what to block off when attaching leak tester to pressurise the intake? I'm running the Forge PCV replacement and catch-can too.
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Visit Craig Cull's Youtube Channel
    You block off the crankcase breather which is the only small pipe next to the pcv. Then pressurise and check for leaks
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
  1. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  2. Boost leak test
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2010, 21:17
  3. Help boost leak test
    By Darrenspain in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2010, 06:38
  4. boost leak pressure test bad for turbo ????
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2010, 13:34
  5. Boost leak test???????
    By malcolm30029085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 13:29
