EM TuningChris Nott
Results 1 to 10 of 10
    Oct 2010
    32
    170 TDi Injector recall
    Just a heads up that there is a recall on right now for Diesel injectors on the TDi 170 VAG engines. I just got all 4 replaced courtesy of Aberdeen Audi.
    arnoldlog's Avatar
    59
    someone at work has had a recall on a passat (55 plate) 2.0tdi 140 for the injectors
    Jun 2010
    South Wales
    69
    One of the blokes I work with had his done last week as the recall. The car then broke down 4 days later. AA reported he had diesel in the oil. Audi have had his car back and have now stripped the engine down to repair. Feel really gutted for him. A3 2007 car too
    Feb 2012
    12
    I there I have a a4 140 bhp 06 reg 2.0 diesel engine code I bre is that code in the recall list
    Jun 2010
    South Wales
    69
    Hi Peter. I have the same engine as you. The recall is only for the 170bhp models so you should be OK.
    Oct 2010
    32
    I have heard of some 140 bhp models being done so worth giving your local Audi dealer a call
    Feb 2012
    London
    Hi Gogsie
    Thanks for this, where did you hear about the recall? My 170 A3 has had a dodgy injector since I bought it 2 years ago. Had the loom cleaned, no luck. I have just emailed Audi Whetstone to have mine done. Will keep you posted.
    I had a remap and dpf removed 18 months ago, hope this wont stop Audi fixing the injectors....... I kept the old pipe, so worse case I can put it back on and remove the remap temporarily.......
    Oct 2010
    32
    No problem, I heard it from an ex VAG technician mate of mine. How do you find the de DPF? Any issues with MOT's?.
    Jun 2011
    NW London
    141
    Quote Originally Posted by mark999 View Post
    Hi Gogsie
    Easy mark go back to your A3 forum..... no only joking c u Sunday his map is awesome btw makes me wanna get my a4 done too.
    Audi A4 2lt 170 TDI Quattro s-line, B7, BRD engine code. Mods so far; cruise control, DPF delete, EGR delete, unicorn remap, B5 perches, RS4 rear arb, RNSE with SDS, 2013 maps with speed cams, aux in, powermax remanufactured balancer, Sachs SRE organic clutch and pressure plate with LUK flywheel. Mods to do; s4 break upgrade, glove box fridge perhaps...
    3DTDi's Avatar
    Jun 2011
    Bristol/Gloucestershire
    239
    All this info chaps is in a very large thread Here: Anyone else with this problem on 2006 2.0 TDi? Injectors...
    It is a huge problem which some of the guys off this forum had to get vosa involved to get vag to prompt the recall.
    A3 2.0TDi 170 S Line Brilliant Black
    Plans: FBMFSW, RNSE MkII, S3 Diffuser and Skirts, OEM Bi-Xenon
  1. Injector Recall for PD170 - Might be already known to you lot.
    By drnutta in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2012, 01:44
  2. Recall injector failure already ?????
    By Baza1819 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2012, 17:53
  3. A3 2.0 TDI Diesel Injector Pipe RECALL
    By mike170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2012, 15:03
  4. 170PD Injector Recall
    By grantDUBshaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 16:50
  5. 170 TDI INJECTOR / LOOM ISSUES - FOUND HTIS ON ANOTHER SITE
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 20:48
