Chris NottBadger5
    May 2010
    scunthorpe
    35
    HELP Bad day at the garage fault code list as long as my arm. 2.0t fsi
    Had the managment light up for a while on my a4 2.0t fsi so thought best take it to my mates garage and plug it in. So once i pulled the codes the results where:-
    P2181-performance malfuncation in cooling system
    P0299-boost pressure regulation control range not reached lower limit reached
    P0441-EVAP Emission control sys incorrect flow lower limit reached
    P0507-Idle control system rpm higher then expected upper limit reached
    P0704-Clutch switch f36 implausible signal no signal/no communication
    P2279-leak in air system lower limit reached intermittent
    Anyone else ever had any of these problems and have any advice cheers.
    Avantageous
    Apr 2010
    Hampshire
    337
    Pretty sure P0299 is your DV gone. Easy to replace, cost about £50 and about 10 minutes.
    And from the sounds of it, P0441 sounds like your MAF.
    Just google each code and you should find fixes to all the problems. Did you clear the codes and scan again? Some may have been very old.
    2011 Audi-Sport.net Fantasy Formula 1 Champion
    2005 Audi A6 3.2FSI S-Line Quattro Stratos Blue
    19x9 S6 / Half Leather Interior / Memory Seats / Black Headlining / S6 Paddle Wheel / S6 Exhaust
    Front & Rear Parking Sensors / TPMS / Adaptive Xenons / Actuated Boot Lid / Bose / Sat Nav / Bluetooth / Sunroof
    Double Glazing / Auto Dimming Interior & Exterior Folding Mirrors / Storage Pack / Lighting Pack
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    I agree, clear codes and see what returns then tackle each one, you can get alot of old codes from things like the battery going flat.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    North East
    607
    Quote Originally Posted by RMH1A4cab View Post
    I am in total agreement with this and the previous posting. No need to worry yet just have the codes cleared and see if they return.
    Paul B7
    chrisa4quat's Avatar
    Sep 2004
    897
    Check for air leaks
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    May 2010
    scunthorpe
    35
    All codes have come back up 2day so will have to get my hands mucky first job check for air leaks and change dv I think. Cheers all for your advice.
  1. Replies: 2
    Last Post: 19th December 2010, 20:41
  2. Bad Company 2 PS3 users add list
    By Turkster in forum Video Gaming
    Last Post: 13th November 2010, 13:45
  3. Replies: 5
    Last Post: 18th January 2010, 23:36
  4. good day/bad day!
    By SteveS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2007, 02:11
  5. Bad, bad day. My S3 got hurt
    By silvers3uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2003, 07:42
