Monster MotorsportEM Tuning
Results 1 to 19 of 19
    chrisa4quat's Avatar
    Sep 2004
    897
    Retrofitted xenons help needed
    Just wired in my xenons (which have been fitted weeks) I have changed the coding etc but I'm having a problem with bulb warning light on one setting or no flash on the other setting. Can anyone assist me please?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Sep 2004
    897
    Anyone? Bulb warning light is doing my head in
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,429
    Maybe you could pm nigel, user (NHN) he is very knowledgeable on these thngs. He may be able to advise you.
    50k
    Dec 2010
    eleicester
    41
    Did you manage to sort it??
    Sep 2004
    897
    Not yet. My high beam works on halogen coding but only with dip be on not sidelights or no lights. Bulb warning on. Or I can get no bulb warning light on no beam on dip lights and dip lights flashing as beam with no lights
    Mar 2011
    northern ireland
    How did you wire them up? I know they have different pin counts kufatec.de do a direct fit loom if that helps
    Sep 2004
    897
    I wired them up with a supplied loom. Maybe it's naff. Maybe I need a control unit. I don't really know
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    id id retro fit mine from halogen to bixenon,
    so what youre saying is. When you have the High beam does not work and you get a warning?
    if it is that then you have connected them wrong, or coded them wrong. the 2 small yeallow pins must be connected rigth for the highbeam to work. and also the code must be right.
    use this code and dont change the thre first codes in VAG
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###21
    i think the origininal code for the halogen is 01012
    If u have the code 21 then the lights work but if not the hight beam then you have connected the small yeallow pins wrong. i did it to after changing it it worked like a charm :D
    Audi A4 2.0TDI 2007 B7 S-Line & Proline
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    For more pics visit my FB http://www.facebook.com/MR.Doberlluka
    For all my mods visit http://www.garaget.org/lenti
    and http://www.audizine.com/forum/member.php/73213-lenti look @ my started threads
    Sep 2004
    897
    My high beam works with dip beam on but not with side lights or
    Lights off. You can hear the lids opening but no light output
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    Wich code did you use on VAG Rosstech?
    maybe it is something wrong with the kufatec cable?
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    Sep 2004
    897
    I don't know If the cable is Kufatec? I have tried all sorts of coding. It is actually coded with halogens at present cos works best that way - confused
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    i wouldnt use halogen code wioth xenon you can brick ure headlights. beacuse xenons need more power than halogen and i think it is dangerous to use the halogen code on xenon but im not sure.
    Try the code i told you in the end with ###21, if that does not work then its something wrong with the lights or the kufatec cable
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    Sep 2004
    897
    The lights seem to work fine. Maybe the wiring. I tried the right coding and high beam does not work on dip beam. And dip beam flashed as high beam when lights off
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    then somethings wrong with the kufatec cable. where did you buy it from?
    i bought mine from this guy
    Kabelbaum Bi Xenon Adapter Scheinwerfer Audi A4 8E B7 | eBay
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    Sep 2004
    897
    It came with the lights
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    if ure using the code ###21 and that does not fix this, then something is wrong with the connections, or you did connect the 2 small cables that needs to be connected under the steering wheel wrong.
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    Sep 2004
    897
    The coding doesn't work. I connected them to pins 16 & 18 from memory
    lenti's Avatar
    Sixth Gear
    Apr 2010
    Sweden
    74
    You need to code them so that the car uses them as Xenons and not halogen, you can destroy the lights and also the electrical system in ure car if you do not change the codes.
    Bluefin Superchip
    218HP/443NM
    RS4 Rims
    _________
    Dec 2012
    Birmingham
    294
    Visit SinghB7's Instagram Channel
    Quote Originally Posted by lenti View Post
    i'm having problems with my coding, when I come to change the code from halogens to xenon it dosn't save. I am using the write code, changing from halogen to ***21 xenon code.
  1. Fitting Bi-Xenons to 8P1 with Factory fit Xenons? Possible? How!?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2013, 21:35
  2. Pre face lift s3 xenons to facelift s3 xenons..
    By donjon in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2011, 17:06
  3. Help needed to centralize my bi-xenons
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2010, 17:48
  4. HELP NEEDED - Xenons retrofit
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th June 2009, 20:35
  5. Retrofitted OEM Xenons
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2008, 09:00
