EM TuningDNA Tuning
Results 1 to 9 of 9
    Jul 2011
    Teesside
    253
    Post Thanks / Like
    Is it worth re-mapping my 2.0 TDi?
    OK guys I've been juggling with this for ages, I first started looking a re-mapping my golf GTi turbo but heard some horror stories about the damage it can cause to an unhealthy engine/gearbox etc.
    Now I have the A4 2.0 TDI S-Line and Im considering a re-map so what do you guys say about it? I would love to hear the pro's and con's, the positive results but also the horror stories like what damage it can cause, what parts it can cause to fail. I know the coilpacks and clutch where the main things on the golf so what about the A4 TDi.
    Cheers guys and girls
    chrisa4quat's Avatar
    Sep 2004
    664
    Post Thanks / Like
    I think it depends on state of car and how you drive it. I personally have mapped all my cars last 4 or 5 and never had any issues. Sadly the turbos have issues on these. Yes it will damage/wear out clutch quicker if you drive hard from standstill. I will be getting my next cars remapped too
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Audi Diesels do love a re-map
    Azure Blue, Pearl Effect
    1.8TQS, KO3s
    3" De-Cat - Straight Through
    Upgraded Coils / NGK / Mobil 1
    Carbonio Carbon Air / Bailey dv26
    Custom Stage 1 Re-map -> chippeduk
    Powerflex DogBone Mounts
    Eibach Pro Kit / ARB
    200 Horses Club
    SUMMER 2012 - KO3 hybrid / Wellycooler / TIP / Injectors
    Aug 2011
    35
    Post Thanks / Like
    But then again... I remapped my 130pd and it didn't like it at all. Dreadful shudder from the flywheel (which was only 2 months old at the time of the remap). The remap people tweaked the torque curve a bit and it made it better, but the shudder was still there. I had it put back to stock, then tried a tuning box about 6 months later with the same results.
    A remap will push the clutch and flywheel close (or in my case, beyond) to their design limits. Whether or not that's an issue seems to depend a bit on luck (I think I was unlucky, because I know there are plenty of people who've had remaps with no issues) and also how you drive it. I do think it's important that you go somewhere reputable that'll help if you have problems.
    HTH.
    2007 A4 Avant 2.0pd 170 quattro S-line special edition
    1990 VW T3 Westfalia Atlantic 2.1 wasserboxer running lpg
    slepy's Avatar
    Sep 2009
    MK
    572
    Post Thanks / Like
    imo NO!
    Even when it's mapped it will be still only a slow diesel...
    That's my thought after being destroyed today by a very nice blonde in a Beemer 130i
    2001 Focus 1.8 TDdi GONE
    1994 BMW 318IS GONE
    2003 Mondeo 2.0TDCI
    Zetec S GONE
    2002 A4 1.9 T
    DI in silver, with blue interior and RS4 style alloys. GONE
    2006 VW Touareg 2.5 TDI SE in sky blue GONE
    2007 A4 S-Line Special Edition Quattro 2.0 TDI 170 in silve
    r GONE
    2007 Seat Leon FR Tdi in yellow :D
    Dec 2011
    York
    81
    Post Thanks / Like
    130i has 260bhp stock, not suprising it wiped 2.0tdi, 3.0 probably has more torque aswell so tdi has nothing on it.
    Remaps are worth it not only for fuel but a little bit more pull, If you want to be wary on the consumables then just dont do any hard boots in 1st, 2nd that will keep flywheel, clutch happier. Turbo will wear quicker reaching higher boost pressures in any gear, Though the turbos on these are renowned for clogging VNT, if your booting it all time youll count this out. Ive had 2.0 tdi's with 120k on same turbo, just VNT has always been problem.
    I vote yes
    kwardy's Avatar
    Southampton
    26
    Post Thanks / Like
    Yes remap is the way. i had my 2.0 TDI 140 remap By Pendle Performance
    Blackie's Avatar
    Feb 2004
    In a house
    400
    Post Thanks / Like
    Yes
    My A3 & Mrs B,s A4 Cab both mapped by the lads @ Awesome who i think have a deal on maps atm.
    I have loads of fun in the A3 & its made the heavy cab miles better.
    MPG has improved as well
    Blackie's Avatar
    Feb 2004
    In a house
    400
    Post Thanks / Like
    Hello mate
    Near Wigan
    The lights as fitted here
    Managed to get some sun & a clean car for once
  1. New A4 quattro tdi - re-mapping
    By beachgang in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 5th December 2011, 21:46
  2. should i consider mapping my tdi 130
    By marktdisport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2011, 01:07
  3. Re-mapping a 2.5 TDI in Aberdeenshire
    By grahamngillian in forum Tuning
    Last Post: 2nd May 2011, 13:07
  4. Mapping a 170 TDI
    By Mikey170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 01:26
  5. Worth re-mapping a 2.0FSI?????
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2005, 16:44
