DTUKGNJ
Results 1 to 9 of 9
    Rastamouse's Avatar
    Welsh Audi Nut
    Aug 2011
    154
    Post Thanks / Like
    Number plate lights not working, any ideas?
    Noticed the other day that 1 if my plate lights had stoped workin, so went about changing the bulb 2 day when i noticed both had stoped working. I had led bulbs in them, so i changed both bulbs back to the original and still nothing? Any ideas? Have had a quick look and cant see any fuse thats related to the plate lights.also the screws for the bulbs holders are rounded too just to make matters worse. Any ideas where i can get replacement screws from?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    3,264
    Post Thanks / Like
    When mine stopped working recently, it was because the tiny plastic "collar" in the lens through which the retaining screw passed was split. It was enough for the bulb-holder to become loose from the housing, and for contact to be lost. I bought a new lens/bulb-holder for about £9. It came with a new retaining screw. I think I might have the invoice with the part number somewhere in the car.
    Jeff:
    A4 3.0TDi SE Quattro Tiptronic
    Life is what happens to you while you're busy making other plans.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    3,264
    Post Thanks / Like
    The part number is A8E0 943 021 B. It was £8.71, and like I said, it came with a nice shiny new screw. The bulb is not included, but the parts man at Bexley Audi was in a good mood that day, and let me have a bulb free of charge.
    Jeff:
    Wrath's Avatar
    Apr 2009
    North East, UK
    898
    Post Thanks / Like
    Evening Easy-Crew,
    The screws are crap, I bought some same size off ebay, think they are used in model cars but don't mash up when you sneeze.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e.
    Nov 2011
    Post Thanks / Like
    So for those of you that have suffered the rounded screws any suggestions to get them out if they're already rounded.
    One of my bulbs has gone (or is loose) and I'm really getting hacked off with the warning flashing on/off and beeping at me every time I go over a bump/change direction etc.
    Thanks in advance
    Macdoon's Avatar
    Essex
    426
    Post Thanks / Like
    Quote Originally Posted by jdp1962 View Post
    Exact same for me, apparently it's another common fault , gimme your money
    A4 B7 (57) 2.0 tdi S-Line 170 Dolphin Grey
    Electric folding mirrors, Tints, Colour coded fog surrounds, Black wheels & Calipers, Ambient light pack, leather, RNS-e(2x mp3 slots), Bluetooth, CD changer, Cruise & DIS, RS4 ARB, Anthracite carbon interior & exterior, RS4 Grille, RS4 style fog surrounds, black s-line badges, black headliner & trims.
    Jan 2012
    Post Thanks / Like
    only way really to get them out is to drill them out or chisel away at the surrounding area of the screw so you can get a pair of pliers onto the head of the screw.when removing the screws i alway spray some silicone lubricant onto them 1st and then use the correct sized screwdriver and use a pair of grips to turn the driver and that seems to work better
  9. Thanks k3lvc thanked for this post
  10. #8
    Nov 2011
    Post Thanks / Like
    Looks like I did better than you - they even removed the old one and fitted the new one for me (but I did have to supply the bulb).
    I can now get on with listening to music rather than the incessant beeping of the warning light
  11. #9
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    3,264
    Post Thanks / Like
    Quote Originally Posted by k3lvc View Post
    Result!
    Jeff:
  1. Another 'help number plate lights not working' thread!
    By Daws88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd March 2011, 08:14
  2. Replies: 2
    Last Post: 14th December 2010, 10:16
  3. 2004 A3 number plate not working
    By gizm0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2010, 17:51
  4. Number Plate Lights not working!!!
    By mdre83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2010, 18:22
  5. UK reg 54 plate 2.4 V6 rear number plate lights not working - CAN Bus issue?
    By A6fella in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 9th December 2008, 14:29
