DNA TuningW8 Performance
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By andymartin045
Thread: Potential purchase
    Sep 2008
    Chepstow, South Wales
    25
    Post Thanks / Like
    Potential purchase
    Hey guys,
    Had a test drive in a B7 2.0TFSI Quattro S-Line today, which I'm considering buying. The spec is good, and it seems to drive OK which is positive.
    On the test drive I had cause to park up for a few mins, and while I did so I had a good look around the car with the engine running. The engine was warm but sounded quite tappy/tappety at idle - is this normal?
    Also, the drivers door handle was loose - it still worked, but was loose to the touch and clunked when the door was slammed - would this be an easy fix do you think?
    Any thoughts?
    North East
    163
    Post Thanks / Like
    I drive a diesel so with that in mind...............
    I understand from other postings on this forum that the tapping noise is a characteristic of the injection system on the petrol Audis.
    Why don't you listen to another and then draw your own conclusions ?
    As to the door handle being lose I would ask why ?
    More importantly if you have ever any doubts about any car, FORGET IT and look elsewhere.
    Remember, a fool and his money are easily parted !
    andymartin045's Avatar
    Sep 2010
    RAF Leeming, North Yorkshire
    27
    Post Thanks / Like
    hi, alex, the tappy sound is quite normal for the tfsi as its all to do with how the fuel is injected at higher pressure than other turbo engines that makes is sound more like a diesel than a petrol. ive been assured by audi master tech's that this is intrinsic of the tfsi engine.
    ive also had a problem with the door handle and its a quick fix; open the handle and you'll be able to see the two silver hinges, simply slide a thin metal ruler or something similar and shunt the handle backwards
    2005 2.0T DTM quattro 281bhp,
    Carbon Fibre, MFSW, BOSE, Bluetooth, Parking Aids, Nav Plus, Recaro Leather & Alcantara, S4 Mirrors, RS4 pedals, H&R springs, RS4 ARB, Spacers, Debadged, Auto Lights/Mirror/Wipers, Silent Forge DV & Vredstein Ultrac Sessanta Tyres. Awful Mileage and some TTS Roadsport stickers!
  5. Thanks alex.stanley thanked for this post
  6. #4
    Jun 2011
    30
    Post Thanks / Like
    I had loose a door handle too. Old rac Plastic card worked a treat with the above method. There are some how ti's with pics on forums reguarding this if u Google it.
    Sent from my HTC Desire using Tapatalk
  7. Thanks alex.stanley thanked for this post
  8. #5
    Sep 2008
    25
    Post Thanks / Like
    Hi guys,
    Thanks for the constructive comments - glad to hear that the tappety noises are normal and the handle is an easy fix.
    @Paul B7, I wasn't having doubts about the car I was merely asking the collective experience of the forum about something that could have been a well known issue and an easy fix. Turns out it was on both counts.
    Thanks everyone
  9. #6
    Sep 2010
    27
    Post Thanks / Like
    If you do get the car, check the coil packs in the engine: simply unplug and lift out using a flathead screw driver on on the thicker lip, pull out and check the part no, it should read 07K 905 715 F the "F" meaning its the latest edition. If you have an earlier letter at the end of the part no., you'll be eligible for 4 brand new coil packs, free of charge, from Audi under their "28E9 Product Enhancement Campaign" ring up Audi and check, your engine will thank you and at about £35-£40 per coil pack, so will your wallet.
    the following VAG engines come under the campaign;
    1.8 ltr TMPI
    2.7 ltr TMPI
    2.8 ltr FSi
    3.0 ltr MPI
    3.2 ltr MPI
    3.2 ltr FSi
    3.6 ltr FSi
    3.7 ltr MPi
    4.2 ltr MPi
    1.8 ltr TFSi
    2.0 ltr MPi
    2.0 ltr FSi
    2.0 ltr TFSi
    2.4 ltr MPi
    4.2 ltr FSi
    5.2 ltr FSi
    6.0 ltr MPI
    (list compiled from Sarge @ Tyresmoke)
    Phantom_A4 likes this.
  10. Thanks mancdan, alex.stanley thanked for this post
  11. #7
    Sep 2008
    25
    Post Thanks / Like
    Super, thanks Andy!
  12. #8
    Sep 2008
    25
    Post Thanks / Like
    By the way, we noticed on the test drive that the interior sun visors didn't have lights with the mirrors like in other cars (like my old A3 and S3s) - is that right?
  13. #9
    bez101's Avatar
    Jul 2008
    3,424
    Post Thanks / Like
    some have the lighting pack some dont
    the engine is noisey over other petrols as mentioned above
    if you cant hear it in the car then it should be about right if you can hear it on tickover in the car forget it
    as above with door handle easy fix
  14. Thanks alex.stanley thanked for this post
  15. #10
    Sep 2008
    25
    Post Thanks / Like
    Thanks all Going to go and have another look at the car later this week (if it's not gone already)..
  16. #11
    Sep 2008
    25
    Post Thanks / Like
    Missed out on that car sadly - it had been sold by the time I got there again
    One question while I look at others on Auto Trader - is it relatively easy to retrofit Sat Nav and Bluetooth, if I find a car that has everything else I want?
  17. #12
    bez101's Avatar
    Jul 2008
    3,424
    Post Thanks / Like
    its very easy to fit nav and bt also dis cruise etc etc
  18. #13
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    234
    Post Thanks / Like
    Quote Originally Posted by andymartin045 View Post
    1.8 ltr TMPI
    2.7 ltr TMPI
    2.8 ltr FSi
    3.0 ltr MPI
    3.2 ltr MPI
    3.2 ltr FSi
    3.6 ltr FSi
    3.7 ltr MPi
    4.2 ltr MPi
    1.8 ltr TFSi
    2.0 ltr MPi
    2.0 ltr FSi
    2.0 ltr TFSi
    2.4 ltr MPi
    4.2 ltr FSi
    5.2 ltr FSi
    6.0 ltr MPI
    I rang up and they told me my car didnt need them doing, ie was unaffected, but I think mines on that list. Its a 4.2 S4 , is that the same as the 4.2s on the list??
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE Speedlines, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
  19. #14
    Sep 2010
    27
    Post Thanks / Like
    Im not too sure, either they have it on record that the coil packs for that particular car have all ready been changed or the list is wrong and your coil packs never needed changing. the easiest way it to check the part number on them and see it matches 07K 905 715 (X) and then see what the last letter is at the end. any earlier than an "F" and they need changing. let me know as you would be in line for 8 coil packs FOC and that'll be saving some serious money! (£320 ish)
  20. #15
    Sep 2008
    25
    Post Thanks / Like
    Have been reading about the 2.0T engine on Wikipedia and apparently in the B7 it comes in 2 variants, a 197bhp and a 220bhp. How can I tell which one is which?
  21. #16
    Jan 2012
    48
    Post Thanks / Like
    The 220bhp version is the DTM edition, to be sure just look in the service book and V5 where it will list the power. 147Kw = 200bhp and 162Kw=220bhp. The engines are the same just a slightly different maping.
    The power is also listed on the vehicle specification sticker which is in the well in the boot where the spare wheel is.
  22. #17
    Jun 2011
    80
    Post Thanks / Like
    Thanks to AndyMartin, am going to go and check my Coil Packs, where ever they are under the bonnet!
    2005 B7 A4 2.0T in Moro Blue
    Interior LED's, 18" 9 Spoke TT Wheels.
  23. #18
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    870
    Post Thanks / Like
    It's not just the dtm version, its the special editions that also have 220
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
  24. #19
    Mar 2011
    55
    Post Thanks / Like
    Engine code for 162kW (220 ​BHP) is BUL
  25. #20
    Sep 2008
    25
    Post Thanks / Like
    Quote Originally Posted by Custardsucker View Post
    Thanks for the responses guys - it would appear that the car I bought yesterday afternoon is a 220BHP variant then
  26. #21
    Jun 2011
    80
    Post Thanks / Like
    1.8 ltr TMPI
    2.7 ltr TMPI
    2.8 ltr FSi
    3.0 ltr MPI
    3.2 ltr MPI
    3.2 ltr FSi
    3.6 ltr FSi
    3.7 ltr MPi
    4.2 ltr MPi
    1.8 ltr TFSi
    2.0 ltr MPi
    2.0 ltr FSi
    2.0 ltr TFSi
    2.4 ltr MPi
    4.2 ltr FSi
    5.2 ltr FSi
    6.0 ltr MPI
    Car booked in at Audi Stockport next week for Coil Pack changeover.
    All they needed was my registration and it brought up the eligible recall immediately.
    Winner, thanks andymartin.
  27. #22
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    234
    Post Thanks / Like
    Eventually got my coil pack out, reads 077 905 115Q, so I take it they are not eligible!
  1. Potential Purchase
    By Vorsprung_Durch_Technik in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 22nd April 2011, 15:24
  2. Ugent Advice needed on potential purchase
    By jq_quint in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2009, 21:04
  3. Potential purchase
    By gwildor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th May 2009, 21:18
  4. RS4 Cab - potential purchase
    By Yellowtrophy in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 5th February 2009, 12:08
  5. Potential purchase
    By batwad in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2006, 15:34
