DTUKUnicorn
    Jun 2011
    West Yorkshire
    11
    Post Thanks / Like
    Unhappy Hot Start problem with brake light flashing.
    Hi
    I have a 55 plate A4, 140bhp, BLB - (ouch, had the balance shaft changed to gear mechanism!)
    It starts fine from cold, however if I've been driving it for a while then turn the engine off, and then start it up again it starts but takes a bit larger than normal and then the brake light flashes 3 times. I've changed all 4 brake disc's/pads, brake fluid level is fine. Can anyone help or is this another common fault??
    Thanks in advance
    Del
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    321
    Post Thanks / Like
    mine does the same, never noticed that it takes longer to start up but just flashed up, i just ignore it and carry on like nothing has happened lol, but will keep my eye on this thread for the answer
    jwhat's Avatar
    Oct 2006
    Ireland
    511
    Post Thanks / Like
    This also happens to me and i just live with it. If anyone has a cheap fix i'm all ears.
    2005 A4 2.0 TDI S-Line, Phantom Black, Black Leather, Alu trim, BOSE, Bluetooth
    Retro'd Rns-E, Multi-Function Steering Wheel, RS4 RARB, Audi Ipod connection, Cruise, DIS and washer sensor, ambient light, Cupra R splitter, Headlight protectors, S4 Alloys, S4 Brakes, RS4 Pedals including dead pedal and a little Audi torch
    To come: Retrofit OEM Xenons, Colour DIS, Bluetooth, coilovers maybe 19's of some sort and a good paint correction wouldn't go astray either!
    Jun 2011
    West Yorkshire
    11
    Post Thanks / Like
    I have moved the wire that connects to the battery near the brake fluid reservoir on top of the reservoir, and the brake light flashing has stopped, but still taking longer to fire up.
    18,275
    Post Thanks / Like
    Could just be the old starter heat soak issue.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
  1. 2.4 V6 hot start problem
    By melteddrummerr in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th July 2011, 00:11
  2. Replies: 1
    Last Post: 12th April 2010, 07:55
  3. Flashing brake light in DIS after xenon install..help
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2009, 21:44
  4. Hot start problem 1.8t
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2009, 20:18
  5. hot start problem a6 2.8 30 valve
    By yendall24 in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 1st April 2007, 03:09
