Monster MotorsportEM Tuning
    steeve's Avatar
    Nov 2004
    UK
    731
    rea light bulb changing?
    Guy at work has a 51 reg A4 saloon, one of his stop light bulbs has blown, how the heck do you access these? There would appear to be no panel in the boot to get at the rear light clusters.
    Any info gratefully received.
    [img]/ubbthreads/images/graemlins/book.gif[/img]
    imported_CurryMilkShake
    Re: rea light bulb changing?
    open the boot -
    Just inside, small Circular panel (2" or so in diameter?)
    Behind which is the nut that holds the light cluster in place..
    From memory, think it might be a 10mm socket required?
    Undo that, the whole cluster will be released, then its just clips to undo to change the bulbs..
    Hope that helps!
    steeve's Avatar
    Nov 2004
    UK
    731
    Thats great thanks ............
