DPMBackdraft Motorsport
    QUATTRO
    Jun 2011
    37
    Post Thanks / Like
    Drain point for air con condense
    Anybody now how to check if drain point for air con condense is blocked ? As my windows are steaming up
    James
    Dec 2010
    125
    Post Thanks / Like
    the drain point is underneath is your ac working q
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    Have the HVAC system scanned for faults. You could have a stuck flap motor.
    A4 (b6) 2.5 TDi QS Saloon.
    QUATTRO
    Jun 2011
    37
    Post Thanks / Like
    Cheers for the info - I'll get it checked out
    I have noticed a sound like one the flaps trying to open ?
    gary3306's Avatar
    Oct 2010
    Northumberland
    838
    Post Thanks / Like
    You may also have a very dirty or damp pollen filter because it is in the plenum chamber. If the drains are blocked, it can give these symptoms
    Suzuki GSX-R 750 K6
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    QUATTRO
    Jun 2011
    37
    Post Thanks / Like
    I've changed the pollen filter, and let off a gas to clear the smell from air con, when I turn the air con on the windows steam up but then clear, the windows will steam up again when the engine is turned off.
  1. Air con drain pipe.
    By chewy. in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2010, 12:17
  2. AIR -CON BLOWING OUT HOT AIR ALL THE TIME!!!!....
    By jondonna8276 in forum Air Conditioning
    Last Post: 31st August 2010, 21:50
  3. Air con still smells even after air-con service
    By Monsoon in forum Air Conditioning
    Last Post: 31st August 2009, 21:08
  4. Air Con - at what point does it operate?!
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2007, 09:21
  5. Air con and Air Quailty Sensor
    By simonwjones in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 23rd July 2006, 17:02
