Sky InsuranceChris Nott
Results 1 to 12 of 12
    Jan 2012
    7
    Paint/Vehicle Info Sticker
    Bit of a numpty question, but only second post on the forum so bear with me... I have searched and just can't find the answer!
    Where is the vehicle data sticker which details the paint code and options located? The threads and posts I have found seemed to suggest that it should be in the rear wheel well, but I have had the spare out twice and looked and it is definitely not there
    Car didn't come with an owners manual so it is not recorded in that. Car is an 06 plate Avant. I've found the tyre pressures sticker inside the o/s/f door and the engine bay sticker on the o/s near the scuttle, but not the one I'm looking for!
    Any advice much appreciated!
    Macdoon's Avatar
    Essex
    1,569
    Lift the boot liner, it should be either stuck to the underside of the liner or in the spare wheel well.
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Jan 2012
    7
    Could it be anywhere else?
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    Wheel well or manual. Only places I know of
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Jun 2011
    Great Melton Norfolk
    1,349
    Could have been removed if been resprayed
    Mar 2011
    112
    I think you will find it under the base of the rear seat.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Lift the boot liner where the spare wheel bit is, the sticker is on the edge there with a load of codes.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jan 2012
    7
    Cheers I will look under the rear seat, it's definitely not in the spare wheel well or under the boot floor.
    Mar 2011
    112
    Let us know if you find it
    Jan 2012
    7
    Quote Originally Posted by Custardsucker View Post
    Thanks for your help, yes it was under the rear seat bench - I wouldn't have thought to look there unless you had said.
    Finding it confirmed the paint code - Mauritius Blue Metallic
    Is there a way of translating the other codes? Are they just all options?
    807
    Yep VW Group Option Codes Decoder
    Put your codes into that and it will tell you what it came with from factory
    Jan 2012
    7
  1. Sticker !
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2011, 18:41
  2. Cannot find paint code on the sticker ?
    By nvc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2009, 01:59
  3. vehicle data sticker
    By bredhurststeve in forum General Technical / How To
    Last Post: 8th January 2008, 08:31
  4. Vehicle options / Vehicle options coding
    By A4 2.0T in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th September 2006, 22:55
