VAG CheckBadger5
Results 1 to 9 of 9
    Dec 2011
    14
    Post Thanks / Like
    what is fault code P02040
    So,
    Audi dealer in France plugs in his VAGCOM into my A4 Avant and says gearbox knackered - 8,000 euros for a new one please.
    He says the Fault Code is P02040 - can someone please tell me what this code translates as?
    thanks
    Stalwart
    13
    Post Thanks / Like
    Google says P02040 = Catalytic inefficiency-bank 1
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    66
    Post Thanks / Like
    You could try this site Audi P0726 OBD/DLC Error Code - Engine Speed Input Circuit Range/Performance I used this when my ECU went on mine. Strange but it says (P02040) code doesn't exist.
    Audi A4 2.0T Fsi S Line Multitronic
    Dec 2011
    14
    Post Thanks / Like
    Quote Originally Posted by m.a.r.k View Post
    Anyone any idea what this then means? Does it have anything to do with a failed gearbox?
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    Have you rung a Audi dealer and asked?
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Dec 2011
    14
    Post Thanks / Like
    Quote Originally Posted by rowdyboy View Post
    2 - Derby & Tamworth Audi - oh, and Audi UK. No use any of them...
    Jan 2012
    48
    Post Thanks / Like
    Quote Originally Posted by jakeA42T View Post
    Could be the code is incorrect, all the codes listed on the site you linked are 1 letter followed by 4 digits so would guess that it is wrong.....
    May 2011
    Bournemouth
    50
    Post Thanks / Like
    Having a look at the fault code list I have found from this site http://www.vaglinks.com/Docs/VW/BentleyPublishers.com_VW_DTC_Table.pdf
    I
    f it was P0204 would relate to this;
    P0204 Cyl.4, Injector Circuit Fault in electrical circuit
    Hybrid Turbo - De-DPF - Weitec Coilovers = Fun!
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    Quote Originally Posted by stalwart View Post
    What do you mean "no use"??? They don't recognise the code or they won't tell you what it means??
    RNS-E retrofitted
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. fault code help please
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2010, 19:59
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
