AMD TechnikAWEsome GTI
    outsideline's Avatar
    Dec 2011
    151
    Post Thanks / Like
    s4 exhaust.... same mounting as 170 tdi?????
    as above just fit my new s4 rear valance, now want the quad exit tail pipes to fill the holes.
    will the standard s4 back exhaust system fit my car, it is also a quattro. already has an exhaust either side.
    cheers
    A4 b7 170bhp quattro | 210bhp remap from Rick @ UNICORN MOTORSPORT ( 07880558534) | DPF deleted | EGR deleted | 19" TSW Zolder 5 custom bronze wheels | rs4 grill | rs4 22mm rear sway bar | lamin-x head lights, fog lights, side repeaters | custom carbon wraped chrome window trims | E M Tuning LED conversion lights | genuine audi s4 rear valance | genuine audi s4 quad exhaust system to fit diesel | cupra R splitter | black audi ring badges | alpine headunit, hertz spl sub with JL audio amp |
    Jul 2006
    Kingston upon Hull, United Kingdom
    178
    Post Thanks / Like
    Very much doubt it tbh as the S4's being the twin pipes all the way from manifold and yours being the single
    During a 4 wheel drift on the M25 i hear from my mate "Dont you ever do that again! Gimme the keys" after 12 hours of owning my old S4
    Dec 2011
    151
    Post Thanks / Like
    they are twin but they are single piped back to the manifold if that makes sence??
    i mean its still a single pipe going into each back box just like mine.
    Jul 2006
    178
    Post Thanks / Like
    But with the S4 having the V8 there is 2 pipes running the full length of the system making joining onto your exhaust very difficult as they only place where you the same number of pipes is right at the very back where it would be a cut and weld job and chances are turn out gash
    Dec 2011
    151
    Post Thanks / Like
    if the standard s4 back boxes would hang on my mounts then i can do the rest, i have a good welder at work, once i have alined the tail pipes i will just drop the full system and cut and weld it where i need.
    i just cant find out whether those 2 back box mountings at the rear are exact same place as the diesels??? its them what will determin where the tail pipes sit on the valance.
    i have been quoted £300 for 2 custom back boxes but sure i can do it cheaper than that.
    Jul 2006
    178
    Post Thanks / Like
    Ah i see then they could quite possibly fit as i had the single exit 2.0tdi 140 replaced with the twin exit 2.0Tfsi exhaust and was a perfect fit so i would say they hangers will be fine for the S4 back boxes as only one place hangers for back boxes can fit
  1. Exhaust on then B7 TDI 170
    By terrymcg in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th February 2012, 20:55
  2. Which after market exhaust for the S line TDI 170??
    By basssound in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th December 2010, 17:25
  3. 170 TDI chrome exhaust tip
    By AudiLad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2010, 22:52
  4. exhaust trims for my A4 2.0 TDI 170
    By BUSTER A4 MISANO in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th July 2007, 10:28
  5. TDi Exhaust mounting positions??
    By VPMD7A in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 24th June 2004, 16:27
