Adrian S FluxKowalski
Results 1 to 11 of 11
    Dec 2011
    27
    Post Thanks / Like
    knock sounds when switch on/off heating 【A4 B7 1.9TDI】
    hi everyone. My car recently having few knock sounds every time i switch on/off the heating. Anyone can give some advice what's that? thanks in advance
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    978
    Post Thanks / Like
    Maybe the flap closing, try it in E mode. Does it only do it when the recircluating button is on?
    JSD 2.59
    Synergy-Solutions
    Dec 2011
    27
    Post Thanks / Like
    the sounds happens :
    every time i turn on/off the key, i mean give the power to the car electric device,but not turn on the engine. doesn't matter the heating is on or off.
    every time i turn on/off the recircluating button
    every time i switch on/off the heating, i mean the "OFF" button.
    but the the knock sounds from "turn on" is different from the sounds from "turn off". sounds like something knocked from two different way.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    815
    Post Thanks / Like
    If the knock is coming from under the dash it could be one of the air distribution flaps sticking - I had this a few months ago and was able to diagnose which motor using VCDS (VAG-COM). On investigation I found that the motor was OK but the operating lever had jammed.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0200) with AMI (250GB hard disk), Bluetooth + HTC Touch HD
    Dec 2011
    27
    Post Thanks / Like
    was on motoway this morning, and it's raining. so i've also found i could hear the same noices as soon i use liquid screen wash, and every time
    Dec 2011
    27
    Post Thanks / Like
    Quote Originally Posted by PetrolDave View Post
    thanks for the experience.but is there anything should be replaced in this case?
    Dec 2011
    27
    Post Thanks / Like
    Quote Originally Posted by sidibear View Post
    E mode doens't make any different,but no noices from switch on/off the E mode
    V6 Quatt's Avatar
    Feb 2008
    220
    Post Thanks / Like
    Dave,
    how did you cure this what methods were used to un jam!!!!! as mine doing the same and wont de -mist windscreen help!! Vag says flapp jamed....
    Torque the Torque
    Dec 2011
    27
    Post Thanks / Like
    Problem found with the air recirculation motor, My part number is : 8E2.820.511D. Made in Spain
    i can't find the exactly same one on ebay. will phone the dealer on Monday
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    978
    Post Thanks / Like
    Quote Originally Posted by Rock View Post
    Ahem, cough.
    JSD 2.59
    Synergy-Solutions
    PetrolDave's Avatar
    Nov 2003
    U.K.
    815
    Post Thanks / Like
    Quote Originally Posted by V6 Quatt View Post
    Dave,
    Removed the motor (3 screws IIRC) and separated it from the mechanism which I checked was free to move by hand and then refitted the motor to the mechanism. That's all I had to do.
  1. I've got a knock knock knocking
    By Jacktdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2010, 11:28
  2. Knock Knock - Whos there - 2nd attempt???
    By DAMO1.9TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th June 2010, 21:15
  3. Two switch Questions...hazard switch and light switch
    By sleeksx in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2008, 23:59
  4. Knock Knock... What possibly cause the knock?
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2008, 22:37
  5. knock knock knockin on audi's door
    By johnyj in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2006, 09:09
