Phantom_A4
Good morning guys.
re: 2.0T DTM
Car started perfectly fine, ticked over for a few minutes and attempted to drive in to work. About 1/2 a mile down the road, the engine completely cut out.....I tried turning the ignition but nothing came up except the abs/tcs light which was slightly flickering, wouldnt tick over at all.
I took the keys out and attempted to lock it remotely but nothing, the needles on the clocks were flicking below zero for some strange reason. Car locked fine with the key. I disconnected to battery completely and left it for 5 minutes, reconnected and it fired up perfectly fine. ESP light was on for the first 10m or so, then the check brakes light flashed on.
Not sure if anyone has seen or had this problem before?
re: 2.0T DTM
