Backdraft MotorsportVAG Check
Thread: A4 B7 DPF codes
    Dec 2011
    6
    Post Thanks / Like
    A4 B7 DPF codes
    Ive got a 2007 A4 B7 with the 2.0 TDI PD 170 engine done 62500 miles
    Was driving and the DPF light came on so i held it above 2200 rpm for 50 minutes or so to self regenerate then the engine management light and the glow plug light came on.
    got it plugged in to VCDS and it came up with a fault code of 008194
    Here the full vcds log
    1 Fault Found:
    008194 - Particulate Trap Bank 1: Efficiency Below Threshold
    P2002 - 006 - Short to Plus
    Freeze Frame:
    Fault Status: 11010001
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 144.0 Nm
    Speed: 0.0 km/h
    (no units): 1.0
    Lambda: 77.3 %
    Pressure: 0.0 mbar
    Time: 439.3 s
    Readiness: N/A
    Can anyone please help with this?
    Sep 2011
    6
    Post Thanks / Like
    18434/P2002/008194
    18434/P2002/008194 - Particle Filter Bank 1: Malfunction
    Possible Symptoms
    • Malfunction Indication Lamp (MIL) active
    Possible Causes
    • Exhaust Pressure Sensor (G450) faulty
    • Diesel Particle Filter (DPF) faulty
    Possible Solutions
    • Check/Replace Exhaust Pressure Sensor (G450)
    Special Notes
    • Skoda Superb (3U) & VW Passat (3B) (Engine Codes: BGW, BSS, BWW) had issues with faulty Exhaust Pressure Sensors (G450), they were defective from factory and due to a leaking sealing the measured values were incorrect and resultet in wrong calculated particle filter load and unsuccessful regeneration cycles.
    That's what Ross-Tec say about it if that helps
    Dec 2011
    6
    Post Thanks / Like
    Cheers for that we did the Measuring blocks and the dpf was 91.7% full so we did a forced regen which took it down to 0,2 % soot level, so were hoping that was all it was and hopefully the g450 sensor is ok.
  1. De Dpf A3
    By Y21SUF in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2011, 14:07
  2. DPF
    By Charlotte in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2010, 11:03
  3. DPF
    By Charlotte in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th April 2010, 10:53
  4. DPF
    By ghouseman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2010, 22:30
  5. DPF-OFF
    By Custom-Code HQ in forum Custom-Code UK
    Last Post: 23rd November 2008, 10:04
