Forge MotorsportBackdraft Motorsport
    Feb 2011
    87
    Post Thanks / Like
    What alloy wheels fit the B7
    Hi guys,
    Done a search and couldnt find anything.
    What alloy wheels fit a a 2005 Audi A4 2.0 tdi S Line (B7).
    Will all non s line alloys fit?
    Is there a list somewhere that I can find out what alloys I can use from the different model and year of cars.
    WANTED
    Aircon Pump for a 2005 Audi A4 2.0 tdi S Line
    Avantageous
    Apr 2010
    Hampshire
    261
    Post Thanks / Like
    Any wheels with a 5x112 bolt pattern will fit. S-Line, non S-Line, no problems. So you wheelws from any Audi except a TT and an A3 will fit.
    The centre bore of the B7 is 56.1, but if you get a set of wheels with a larger centre bore, it isn't a problem.
    Stepho's Avatar
    Feb 2004
    Strathclyde
    415
    Post Thanks / Like
    Quote Originally Posted by ChrisFurlong View Post
    Centre bore is 57.1 sure this is just a typo Eh Chris. New TT and A3 wheels will fit also as they are 5x112 the earlier versions were 5x100 so don't fit. Plenty of aftermarket wheels out there offset wise anything from 45 to 35. Ideal fitment size below:
    5x112/8.5J/ET45/R19 fitted with 235/35/19 tyres
    Feb 2011
    87
    Post Thanks / Like
    Thanks for the info guys.
    I am looking for cheap genuine 16/17 inch alloys to stick some winter tyres on.
    Does this mean that I can fit wheels from any age A4/A6?
    WANTED
    Stepho's Avatar
    Feb 2004
    Strathclyde
    415
    Post Thanks / Like
    any B6 or B7 A4 wheels should fit. Unless its an s-line where the smallest wheels will be 17". Think its to clear the brakes.
    gavsman's Avatar
    Sep 2011
    Croydon
    330
    Post Thanks / Like
    Also A6,A8 & VW Sharan wheels will fit, what size brakes do you have? I have 312mm brakes on the front & 16's just fit over them.
    This site has a chart to show the pcd, bore & offset: Alloy wheel fitment guide and pcd's.
    Audi A4 B6 1.9 TDI 130 Sport ( 2001)
  1. Alloy Wheels - Will They Fit?
    By SamA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th November 2011, 16:17
  2. Replies: 14
    Last Post: 6th November 2011, 21:56
  3. Alloy wheels: What OEM wheels will fit / seeking OEM items.
    By DavieMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th January 2011, 22:11
  4. S-line / RS6's Alloy wheels - differences and best fit for A4 cab
    By golf kid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2010, 16:14
  5. How To Fit Alloy mirrors?
    By rizwankhan2001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2009, 19:25
