W8 PerformanceEM Tuning
Like Tree1Likes
  • 1 Post By jaygeezer871
Thread: DPF reset, has It worked for anyone?
    Oct 2009
    133
    Post Thanks / Like
    The light has just come on, I have read the threads about removal etc but has anyone actually had success with the 60kmh drive for 15 minutes at 2000rpm in 4th or 5th as per the manual?
    Audi A4 Avant TDI 170 S-Line
    1992 Saab 900 T16S Convertible
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    I tried this but it didn't work So I had it taken off and cleaned out and now all is good. I think the outside temperature is to cold for the exhaust to get hot enough for the cleaning cycle to activate.. Now all is well just gonna stay away from supermarket fuels and use a DPF cleaner once a month and fingers crossed I don't see the DPF warning light again
    Oct 2009
    133
    Post Thanks / Like
    It worked!!!!
    Just got back from giving it a run, drove it over 2000 rpm for about 10 mins and the light went out, what a relief!
    My theory also was the cold temperatures not letting it get hot enough.
    With the cost of diesel I have been driving more sensibly so not really had her up in the revs which I'm sure hasn't helped as I do a 20 min stint on the motorway daily, oh well will gave to go back to doing 80mph everywhere.
    Will look into preventative measures more closely.
    craig_TDI likes this.
    chrisa4quat's Avatar
    Sep 2004
    664
    Post Thanks / Like
    It may need longer but as long as its done when light first comes on it should be fine
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    Quote Originally Posted by jaygeezer871 View Post
    It's totally normal for the DPF warning light to come on then take it for a blast to get it off.. So iv read. I'd be more worried if it didn't come on to warn me when I need to take it for a blast to active the cycle.
    icenutter's Avatar
    Jun 2006
    594
    Post Thanks / Like
    When the light has DPF light came on on mine, I just drove in 5th instead of 6th on the Motorway for a while and that sorted it.
  1. Service interval reset after ECU code reset
    By mikedavey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2010, 20:08
  2. spare key...worked...then didnt??
    By ian 06 A3 2.0 tdi s line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2010, 23:22
  3. if my dis worked id fit this!
    By olds_kool in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th October 2008, 21:55
  4. Aircon - worked this morning - not now!!
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2007, 21:19
  5. Sony Amp in an A3, worked.....now doesn't
    By imported_tobycruse in forum In-Car Entertainment
    Last Post: 18th November 2004, 23:17
