I have a A4 Avant 2.0tdi and over the last week i have noticed a massive loss of MPG
Town driving i am only getting mid 20mpg and on a 60mph 40 mile run i only managed around 37mpg !
Anyone any ideas as to what might have happened ???????????
During a 4 wheel drift on the M25 i hear from my mate "Dont you ever do that again! Gimme the keys" after 12 hours of owning my old S4
Possibly because of the drop in temperature which results in a richer fuel mixture while the car is cold.
Nathan
Red Audi A4 B7 S-Line with Leather/Alcantara interior
Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e.
A work colleagued experienced similar symptoms on his 2006 model.
This was corrected when Audi replaced his injectors.
Yeh could be the temp but i wouldnt have expected that much of a drop ?
God i hope it aint the injectors going replacing them just aint gonna happen !!
It does make a heck of a difference as it does take a while for your car to get up to temperature and hoofing it while still cold compounds the issue. Watch what it's like when/if we get a warm day or reset the mpg once up to temperature.
Nathan
Check for boost leaks
Cover up your radiator using cardboard or something similar like all the black cabs do! It'll keep your car warmer in this weather and you'll benefit from slightly better mpg.
Dont use your heating to warm up the car until at least the coolant needle is bang in the middle otherwise your just stealing all the engine heat for yourself and thus the engine doesn't burn efficiently!
Maybe run some Forte Advanced Diesel treatment through the tank to see if it helps. Google it including uk mkivs and read the thread on the ukmkiv forum. The boys seem to like it!
Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
Nathan
No problem. Always happy to help![]()
Nathan
