DTUKVAG Check
Results 1 to 9 of 9
    Jun 2009
    Post Thanks / Like
    Bi-Xenon light problem b7
    Hi guys,
    I have been experiencing the xenon flickering issues with my b7 a4, both side, got checked by audi during servicing and they said no error comes up, and they said the battery was having low voltage. The problem still exist now, and thinking to change a set of bulb and see if its cure the problem, is anyone of you know which xenon bulb it use on b7 ?
    Sam
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    659
    Post Thanks / Like
    Providing it's the bi xenon HID setup they will be a D1s fitting like these Replacement D1S HID Xenon headlight bulbs.
    I've always said - "One day I'll be able to afford a BMW, and when that day comes I'm gonna buy an Audi"
    Jun 2011
    Warham, Norfolk, United Kingdom
    108
    Post Thanks / Like
    Had a drivers bulb flickering and going out on me every now and then. Have since changed both bulbs and theyve been fine since. However it does look like they flicker around here with all the bumps/pot holes and auto level. Got brand new Genuine bulbs off Ebay for £35 each
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line<br>K&amp;N oil and air filter, RS6 18" Alloys, Cupra R Lip, MTec Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses
    Jan 2011
    53
    Post Thanks / Like
    Sorry to bump this up! So I too have the flickering Xenon and i'm just coming up on the MOT. My problem is its always worse when the light is first turned on, for the first 5 mins its can be really bad, but not always... I have read so many posts on this problem I have lost any idea what the actual problem is, is it bulbs? if it's that simple I will stick two new ones in.
    All sensible comments welcome.
    Phil
    bez101's Avatar
    Jul 2008
    3,424
    Post Thanks / Like
    try bulbs 1st
    they if not sorted ballasts
    Jun 2009
    Post Thanks / Like
    Got it checked by Audi, they said bulb and control unit (ballast) both faulty.
    The flickering was bad when the car first start, and seems alright after a while. Probably will change e control unit and bulbs
    UnderwaterPilot
    Sep 2007
    7
    Post Thanks / Like
    my a3 xenon drivers side flickers for first 5 minutes also, have looked at history the control unit was changed previously on my car!!! did the change of bulbs/control unit work??
    Driving - A4 2.0 TDI S-Line Jet black....Nice!
    chrisa4quat's Avatar
    Sep 2004
    664
    Post Thanks / Like
    My passenger bulb goes off within first few seconds of starting car on auto lights. Turn it off and on again seems ok. Don't know where I go myself
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    wyliss's Avatar
    Aug 2004
    North West
    144
    Post Thanks / Like
    I have had this issue before. The dealer ended up changing both control units that are positioned below each lamp.
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Phatnoise, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser.
  1. Xenon problem.
    By gaz j in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2010, 23:10
  2. problem with xenon
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2008, 16:32
  3. xenon problem
    By cjp2k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2007, 21:08
  4. Xenon Problem
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2007, 02:18
  5. Xenon problem...
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2005, 17:14
