UnicornDPM
Results 1 to 10 of 10
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    HELP!!! Warning symbol.
    Alright everyone, was on my way to work this morning and my petrol light came on then a couple of minuets after this light appeared.. Can anyone tell me what it means please. Thanks
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    DPF blocked, check your handbook
    Sometimes a drive at highish revs will clear the filter and the light will go off
    A4 (b6) 2.5 TDi QS Saloon.
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    Quote Originally Posted by kite View Post
    Thanks alot, I'll give it ago.. What happens if it doesn't clear?
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    if it won't clear you'll have to take to a dealer.
    Might be worth scanning for faults if it won't clear.
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    Ok thanks alot... If I have to go to the dealer how much am I lookin at... Money wise?
    macpdm's Avatar
    Jul 2011
    Cheshire
    356
    Post Thanks / Like
    Isnt it about 30 - 40 quid for the dealer to scan or check out the VCDS map on the forum as you may have a forum member with VCDS who will help you out.
    Edit:
    There you go http://www.audi-sport.net/vb/vcds-fo...rs-map***.html
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    677
    Post Thanks / Like
    I think to activate the cleaning cycle you have to drive at over 50 for 15 minutes, if I remember correctly.
    Someone on here was quoted £1500 from Audi when there's was blocked and needed replacing.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    ScottB5's Avatar
    Nov 2010
    Plymouth
    9,286
    Post Thanks / Like
    Blog Entries
    here is a option on VCDS to do a clean cycle on the DPF.
    Best thing for now is to get it up to temp, go for a nice long drive at highish revs to someones house with VCDS.
    That should do it.
    I read somewhere that you have a couple of days to do the long drive, to clean/regen the filter before it is a trip to the stealers to get them to look at it.
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    Thanks alot for all your replys and help... I'll take it for a nice long drive and hopefully it'll disappear..
    craig_TDI's Avatar
    Nov 2011
    Manchester, UK
    26
    Post Thanks / Like
    I took it for a drive out and did what the manual said but it didn't work.. Now iv got a flashing glow plug light, permanent engine management light and limp mode!!!!!! Not happy so seriously considering this permanent fix only problem is gettin my car from Manchester to Newcastle in limp mode..
  1. Brake warning symbol
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th October 2011, 13:49
  2. Warning symbol :S
    By jamies in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2011, 14:30
  3. warning symbol???
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2010, 23:00
  4. Warning symbol (0) help please
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2008, 09:01
  5. Warning symbol ? (O) ?
    By roydonaldson in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2007, 14:06
