mfsw.
Hi Rob,
You need to remove the top cowling, this can be done by removing the 2 T8 screws from the bottom cowling that is securing on the top. Lift up the top cowling and there should be a white label ontop of the Steering ECU which will denote the following:
Lowline
  • Supported Steering Wheels: Standard Steering Wheel (4-Spoke)
  • Supported Features: Trip Computer (does NOT support Cruise Control!)
  • Part Numbers: 8E0-953-549-F 8E0-953-549-S
Midline
  • Supported Steering Wheels: Standard Steering Wheel (4-Spoke), Sport Steering Wheel (3-Spoke), Multi-Function Steering Wheel
  • Supported Features: Trip Computer, Cruise Control
  • Part Numbers: 8E0-953-549-L, 8E0-953-549-N
Highline
  • Supported Features: Trip Computer, Cruise Control, Steering Wheel Heating
  • Part Numbers: 8E0-953-549-M, 8E0-953-549-P, 8E0-953-549-Q, 8E0-953-549-R
You will need a Midline/Highline ECU to support MFSW.
Do you have Cruise Control? If so then you already have the correct ECU for the retrofit.
6
544
10
737
10
2K
488
