Sky InsuranceChris Nott
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Windscreen replacement - felt pad.
    Anyone with autodim mirror and/or autolights had their windscreen replaced? Do you know where to get a replacement felt pad from that sits between the sensor and the windscreen? Apparently it has no ETKA number.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Oct 2011
    16
    Quote Originally Posted by Wrath View Post
    Sorry to say this mate but you need to buy the whole sensor from audi as you cant buy the jelly that goes between the screen and sensor, sometime you dont need to replace it but you have to wait for more water to land on the sensor, pour water over the screen where the sensor is, if the wipers work dont worry but if they dont then a new sensor is needed, im a windscreen fitter and run a windscreen company so any more info needed just ask
    Oct 2011
    16
    i did try to reply to your pm but it wouldnt let me as i havent posted enough post yet, so i will answer here, the sensor boss is one the screen but the sensor itself is seperate, if you send me the ebay item number i will have a look and tell you what you need and if its a good price
    Oct 2011
    16
    replying here again sorry,Im in ipswich, suffolk,where abouts are you? i would check the price at audi before you buy it as that one doesnt look new to me, screen is a good price but just remember that you will have to pay someone to fit it probley around £50, the sensor goes on the screen its easy once every thing is off, done my own this afternoon, took about half hour to do whole job,
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I'm up in the NE, bit of a distance
    I've bought stuff from them before so i think it is new, just someone's old stock. There is another for about £20 more but wondering whether I should stop retrofitting stuff or do this as one last go. I don't want to end up getting a windscreen fitted and find it's the wrong one.
    Nathan
    Oct 2011
    16
    to be honest if you havent got a sensored screen i wouldnt bother as its more hassle then its worth,
  1. Rear Brake Pad Replacement.
    By a3a3a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th May 2011, 03:34
  2. Rear brake pad replacement
    By stevebuba in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th June 2010, 20:09
  3. Rear pad replacement at 35000km?!?!?!?...
    By Gryphon001 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2009, 08:27
  4. Help on Brake pad replacement
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2006, 22:22
  5. brake pad replacement
    By j2gheart in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th September 2005, 21:12
