*** Firstly please excuse me if this topic has already been covered I appologise in advance ***
Hi Guys Iâm new to this site and to be honest I havenât really had a chance to look through the forum properly other than flicking through the balance tensioner stuff.
I have made a post but unfortunately got no reply
A few weeks (maybe a month ago) back the engine oil light came on the dash I stopped at the local petrol station and bought some oil and topped it up, light went off and all seemed fine until now. 2 weeks ago the car was lacking power letting out lots of black smoke intermittently, I managed to get home and parked it up when I tried to start it back up it fired up but went straight back off, i tried this a few times and same thing it starts up but turns straight back off, noticed its smokes from the exhaust when I try and start it.
Today I got a friend to hook it up to a computer and i got the following and I really am clueless on what to do next, has anyone experienced this or can someone tell me what I need to do? I donât know any good mechanics and cannot afford to go to the stealers
VCDS Version: Beta 812.4
Address 01: Engine
Control Module Part Number: 03G 906 016 GN
Component and/or Version: R4 2,0L EDC G000SG 9618
Software Coding: 0000072
Work Shop Code: WSC 00732
6 Faults Found
17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 000 - -
Freeze Frame
RPM: 840 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame
RPM: 840 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame
RPM: 840 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101100
Temperature: 15.3°C
Bin. Bits: 10110000
16787 - EGR Valve (N18): Malfunction
P0403 - 000 - - - Intermittent
Freeze Frame
RPM: 1890 /min
Torque: 64.0 Nm
Speed: 44.0 km/h
Duty Cycle: 84.4 %
Voltage: 14.06 V
Mass Air / Rev.: 685.0 mg/str
Duty Cycle: 21.3 %
Bin. Bits: 00000000
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 000 - - - Intermittent
Freeze Frame
RPM: 1008 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 99.6 %
Bin. Bits: 00101100
Mass Air / Rev.: 510.0 mg/str
Mass Air / Rev.: 0.0 mg/str
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - - - Intermittent
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 351.4 Nm
Readiness: 0 3 0 0 0
