AH FabricationsJMB Retrofits
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Rock
Thread: I just started getting a knocking noise
    StateOfPlay's Avatar
    2,230
    Since the weekend I have noticed a knocking noise whilst driving, usually at speeds of around 20-40 mph, but not when doing 70mph on the motorway.
    It is a knock knock knock, coming from the near side front, thought it was something in the glove box but it isn't that. Is it a shock or suspension problem?
    Live your life as if nobody is watching you.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    i was thinking hooker in the boot till you said front end
    could be 1 of the arms
    2,230
    The hooker in the boot died weeks ago, she stinks but she beats buying a boot tidy any day of the week.
    Oh right, an arm eh, expensive job?
    bez101's Avatar
    Jul 2008
    8,492
    well if its a arm theres 2 lower 2 upper and that c shaped link things
    they have gone on me a few times prety cheap for them and easy to fit
    when ever iv had probs with the arms iv changed them as a kit all 10
    2,230
    I will find a local garage and get an estimate, not taking it to Audi in case they charge me for the hooker.
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    I have a noise on mine too ,only happens at low speed when i'm pulling on and off my drive ,we had a quick look recently when i had thefront spring plates changed,all the bolts were seized solid ,took mark(byzan) ages to free everything off,but we couldn't see anything obvious.Bez how much are the parts if you change the set?and where did you get them,dealer,ebay?,cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    2,230
    I took it into the garage this week, they checked the car over and cannot find anything wrong with it.
    What they reckon is that when I had my phone kit fitted the guy took out the dash. As the car is a convertible and not as structurally secure as a non convertible the car has become less rigid and the knocking noise is coming from the dash or the glovebox.
    So I have got to put up with this noise. Bugger!
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Probably the control arms - mine have just gone but on the ramp, you can't tell - the suspension needs to be under tension.
    Take a wheel off & pry against the control arms with a pole of some description to see if there is any play in the bushing.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    2,230
    The knocking noise is getting worse. The Bosch service centre had it for a day and say there is nothing wrong with the car.
    They say it is the dashboard and that there is nothing I can do as they are not solid built chassis coz it is a convertible.
    Anyone got any ideas??
    Mar 2011
    112
    Check the Anti Roll bar connecting links from the bar to arm. Have known these fail on many cars and give a knocking noise at low speed. I usually take them off to check as you only need a very small amount of play to cause quite a lot of noise.
    bez101's Avatar
    Jul 2008
    8,492
    one place i would check is the strut
    reason is
    iv got a golf gti bad knocking from pass side front
    all arms checked bushes top mounts etc etc nothing wrong
    jack car up and grab the plunger on the strut see if theres any play in it
    worth a look
    Dec 2011
    27
    Rheady likes this.
    Feb 2006
    derby uk
    39
    Sounds a bit daft this, but have you checked the wheel nuts are tight/ My mate came round with a knocking noise on his and the wheel was loose. The guy who painted the wheels didn't tighten one of them up!
    worth a look?
    Nov 2003
    London (N8)
    515
    Just for reference, my knocking is still there after swapping all the control arms, drop links, etc.
    I've ordered a new top mount bush as that seems like the only other thing it could be, other than a dead shock absorber.
    Should have it fitted and fixed this coming weekend - fingers crossed it's just the bushing!
    2,230
    Solved it!
    Opened passenger door wide and noticed that there is painted metal against painted metal knocking against each other at the back of the bottom door hinge.
    Sprayed some grease onto it, and hey presto! It is bloody perfect now!
    Nov 2003
    London (N8)
    515
    Mine was a small rubber bush that sat between the top mount and the strut itself. The top of the strut was knocking on the mount.
    2,230
    Looks like me and ultramodz are now experts in knockers.
  1. clicking noise when started from cold?????
    By Leaky Lloyd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2011, 11:09
  2. S3 knocking noise?
    By gynads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2010, 17:45
  3. Problem number 1 of ownership! Grinding noise and knocking noise help!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2010, 09:17
  4. whining noise started and esp light come on
    By liamquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2010, 12:49
  5. loud blowing noise coming from engine when started up......?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 17:55
