    Oct 2011
    Essex
    38
    New Owner - Loads of questions re styling, lights etc...
    Hi guys,
    I fancy doing a few subtle mods just to personalise the car.
    I am thinking, interior leds, exterior led bulbs wherever possible for the number plates sidelights fogs etc.
    Also would like to get the new style LED DRL headlights but haven't a clue where to start looking.
    Finally for now also thinking about either changing or making the grill black as oppossed to the standard chrome.
    I don't want this to look chavvy and quite like it all to still look stock, but just different.
    So fire away with suggestions, links and any other ideas.
    Car is a A4 3.0TDi Quattro Avant in dark metallic grey.
    David
    Last edited by David Cook; 8th November 2011 at 10:31. Reason: forgot car description
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Quote Originally Posted by David Cook View Post
    Hi guys,
    Hi, and welcome. Nothing wrong with a little personalisation of your pride and joy.
    Good start.
    Interior LED's are easy and quick to do. Will not throw error codes at all, and look really good.
    Throwing LED's into the exterior lights gets a little more complicated since you run the risk of errors popping up on your DIS.
    I've decided to do away with my error throwing LED number plate lights and replacing them with White xenon look bulbs.
    You can do the same with your side lights (I assume you're referring to the DRL lights in your headlights) and your fog lights.
    If you insist on LED's, then either try source error free canbus ones or install load resistors, but be aware, these put out a LOT of heat and I'd avoid them TBH.
    eBay is your friend here, but someone might be able to point you to a local UK/Euro supplier (I can't help as I'm based in South Africa)
    Another mod that looks good. you might even want to consider an RS4 type grille.
    Very nice!!!
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    Try bmtown for lights and styling,they have some nice a4 stuff,welcome ,cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    northernlight's Avatar
    Sep 2011
    56
    Read this thread with interest as I'd like to replace my very yellow looking DRL's for something whiter as well. They do look rather antique next tot he xenons!
    I was under the impression from previous searching that these bulbs were quite rare and thus i gave up as i couldn't be bothered with the LED route. Does anyone know what the OEM DRL bulbs are and ideas for whiter replacements?
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Quote Originally Posted by northernlight View Post
    You'll need similar to these:
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    The bulb type is 1156
  1. New Owner with Questions
    By fugel in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th June 2011, 17:28
  2. Loads of Newbie questions - Be kind!
    By bristolbaron in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 19:45
  3. New A6 owner = questions
    By ex-vag in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st December 2010, 18:01
  4. New owner has some questions
    By toathus in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2010, 10:07
  5. New owner, few questions..
    By emerylloyd in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2007, 09:15
