Sky InsuranceChris Nott
Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By GRAHAM RS4
  • 1 Post By robmeister1969
Thread: Audi A4 Cab roof problems PLEASE HELP
    Oct 2011
    Hi well i put the roof down on my audi the other day then when i went to put it back up the cover opend then that was it so i closed it using the t-handle key thing then when i try open it now the front uncatches and roof opens about 1.5 inch and then nothing else happens i have tried resetting it by opening/closing with the key
    when i scaned it for faults on vag-com there is no faults showing
    the only thing i can see is that the measure blocks is giving outputs of
    11011010100110 i dont think this is correct but not sure
    any help gratley recived
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    356
    Hi mate,
    Can you hear the hydraulic pump whining ?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    you prob have a sensor down
    Amason007's Avatar
    Nov 2011
    SE London/Kent
    117
    Have you looked at this? Maybe of help to you?
    Audi A4 (8E) Automatic Roof - Ross-Tech Wiki
    Feb 2011
    356
    I have ELSA so let me know if you need any diagrams, procedures or exploded views
    Mar 2012
    hiya fellas ,
    i think i might have the same problem (or similar) as geordie. i was cleaning the car yesterday , put the roof down to give it a polish ,it came with no problems.
    went to put the roof back up and thats when the problem arose , the back flap came up around 2 inches then stopped. i the put up the roof manually (with the tbar hoojimmyflop thingy) and then tried to operate it normally after that , and exactly the same happened approx 2 ins and stopped ,
    any answers anyone .
    Feb 2011
    356
    Quote Originally Posted by big smudge 579 View Post
    hiya fellas ,
    Hello "Big Smudge"
    What year is the car? Have you got any fault codes? If not I have had the same problem in mine and wrote a guide how to repair:
    Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    It is due to poor contact between the brushes and motor commutator, as the brushes wear they stop travelling freely in the brush carrier this causes them to arc and leave deposits on the commutator. Take off the motor bell housing, clean the commutator with some fine sand paper and do not forget to open up the brush carrier by prying with a screw driver to stop it happening again.
    Mar 2012
    hiya fellas , <br>i think i might have the same problem (or similar) as geordie. i was cleaning the car yesterday , put the roof down to give it a polish ,it came with no problems. <br>went to put the roof back up and thats when the problem arose , the back flap came up around 2 inches then stopped. i the put up the roof manually (with the tbar hoojimmyflop thingy) and then tried to operate it normally after that&nbsp; , and exactly the same happened approx 2 ins and stopped , <br><br>any answers anyone .
    Mar 2012
    hello krumz , thanks for that reply mate much aprreciate it , however i know nothing about cars but theres a lad whos going to look at it for me on monday who is an auto electrician and ill pass on that info , but ill also look at the link you sent me .
    thanks krumz
    true gent
    Feb 2011
    356
    No worries, Id recommend for him to check if there is power coming to the motor using a multimeter and if it is, then just to follow the guide.....
    If you are in the Midlands I can have a look at it for you.....
    bez101's Avatar
    Jul 2008
    8,472
    1st off id have the fault codes read
    theres so many sensors etc its prety hard to say whats what
    bearder2006's Avatar
    Jun 2009
    205
    sounds like what ours did krumz
    Feb 2011
    356
    Quote Originally Posted by bearder2006 View Post
    Hi Jay, where did you come from mate ? Lol trust you and your Audi are well
    Mar 2012
    Krumz. Excellent write-up on roof problems and the commutator needing to be cleaned. My girlfriends 2006 A4 developed a fault last year and she asked Audi to investigate as part of the minor service. It went in last week. Audi spent 2 hours (ca £240) investigating and said they found a short which they repaired however that didn't fix it. We went to collect yesterday. They have diagnosed a fault with the roof motor/ hydraulic pump and are quoting just over £1,000 for a replacement plus 2 hours labour, a relay and top-up fluid. In total, nearly £1,600. I followed your excellent instructions and removed the casing to the motor. The commutator had a dark band which i cleaned with wet and dry. I also cleaned the 'lines' with a blade and sprayed WD40 on the brushes (I didn't didn't try to free them though?). Unfortunately still not working (the roof will still lift only a couple of inches). I climbed in to the boot and had my girlfriend start the engine and try to operate the roof. There were no noises from the pump other than some clicks which I think were the relays. Just wondering if there is any thing else I might be missing? I have found a repair service on ebay which at £75 seems reasonable. Just for further guidance, where would i need to connect a multimeter to test if the motor is receiving power and would someone need to operate the roof switch at the same time? Many thanks..
    Sep 2010
    krumz,,,i had a problem with my rs4 (been off road for winter) cab roof 06 with only 34,000miles on clock,,i used your guide and i fixed it,,,thank you very much.
    VagPro likes this.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I would clean the wd40 off it for a start. It needs a dry contact to make connection, wd40 will make it worse.
    Mar 2012
    Quote Originally Posted by Blackie View Post
    Thanks Blackie. I should have said that i sprayed the WD40 on the arms to the brushes rather than directly.
    Feb 2011
    356
    Quote Originally Posted by robmeister1969 View Post
    Hello Rob,
    I had a problem once where I cleaned the commutator but as the brushes were stuck in the guide they were not making contact and hence the roof did not work. Few things to do:
    1 - Stick the multimeter on the two wires going to the motor and see if it is getting power by operating the boot switch. If it is then it is the motor (£180.00) from Audi or the brushes might be stuck. The repair service on ebay would cover that too.
    2 - Get a diagnostic done and see the fault codes you are getting
    Even if it is the hydraulic control unit
    Sanburn breakers will get you one for a few 100£. Give them a call, speak to Wayne or Dave tell them Khurrum has pointed you in their direction and get a price for the unit (if they have it) 02476637376
    Also BBA Reman may be able to repair it.
    If you need to have a chat drop me your email add and I will send you my phone number
    Mar 2012
    Just want to make a quick mention to autoelectron on eBay. As per my question to Krumz following his excellent write-up, I still had a problem with my roof motor having cleaned the commutator. I found autoelectron's repair service on eBay where for £74.95 he tests, repairs and posts back your roof motor. I literally posted my motor to Mervyn in Yorkshire from Surrey at 2pm on Friday. I received a text on Saturday to say that the motor had been received, repaired and tested and was being posted back. It was received on Monday and I fitted it this evening and the roof is now once again working for the first time in over a year. The next job is to get on to Audi's head office and question why their diagnosis took two hours (£240) and how they can happily justify their quote to repair the roof by replacing the motor and hydraulic pump at a cost of £1,600!
    VagPro likes this.
    Mar 2009
    470
    Good result and what great service. Nice to hear a happy ending.
    Thats why they are known as the stealers.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Apr 2012
    Hertfordshire
    Got a similar problem, the rear window section of the hood is not moving hydraulically and putting the hood sensors out of sync. Hydraulic motor works for all the other stages of opening and shutting so thats ok. Are there sensors for each phase of opening and shutting and is there a list/diagram of them anywhere please?
    Great write up Krumz and helpful threads have got me this far.
    Andy
  1. Problems with roof on A4 Cab
    By chiefwiggumpi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th October 2009, 12:31
  2. HELP with audi a4 cab roof and boot
    By little ted in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st May 2009, 11:14
  3. Hello from a 09 plate A3 cab owner with roof problems!!
    By Filthygorgeous in forum The Welcome Section
    Last Post: 17th April 2009, 21:11
  4. Newbie audi 80 cabrio, roof problems, noises
    By kghowe in forum Classic Audi Forum
    Last Post: 17th July 2007, 08:52
  5. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
