EM TuningSky Insurance
    Gog
    Jun 2006
    6
    squealing aux belt, any way of telling if its the tensioner or alternator clutch??
    hi
    my 2005 2.0 a4 tdi 60k miles has developed an aux belt squeal whilst steering at low speeds and when at full lock. theres no loss of pas fluid and no leaks around the pump or rack.
    from what i've read it seems that the tensioner and the alternator pulley are the most likely culprits.
    anyone know of any tips to narrow it down to one or the other?
    also is it possible to just remove the front grill and rads to get to the tensioner if it is that? i don't have a manual atm as up to now we've only had to service it which has all been at main dealer to keep up the stamp.
    any recommendations on a decent manual for it?
    many thanks for your time.
    johnny161171's Avatar
    Jun 2011
    Lincolnshire
    50
    Hi mate take the belt off the alternator at the alternator and see how quick the alternator pulley is spinning this is a common fault on Audi's for them to sieze up i see your car is a 2005 so i guess that if you have been serviceing with a main dealer all the time then they would of changed the tensioner at some point as that is a serviceable item and the alternator pulley isn't, you will need to have the alternator pulley replaced only and you will need a buzz gun to get the pulley off the alternator. Haynes manual's are pretty good for basic know how.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    changed a few weak belt tensioners in the past could be the culprit... usually around £60-70
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. Help please - aux belt tensioner
    By Ian_83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 18:56
  2. Squealing belt type noise
    By OldRedEyes in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th October 2010, 18:51
  3. Alternator Belt/ tensioner pulley
    By S1MON A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2010, 21:41
  4. a few issues with my 2.0 tdi (poor mpg and suspected alternator belt tensioner seizin
    By andy16vturbo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th March 2010, 02:18
  5. Change alternator belt at same time as cam belt???
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2009, 11:38
