Volks AutosSky Insurance
Results 1 to 8 of 8
    Jul 2011
    Teesside
    327
    Anything I can do with my dull headlights?
    When I say dull, I dont mean the bulbs, there sorted. I mean the headlight glass, well mines plastic but....
    There chipped to hell and quite poor looking as well as maybe effecting the quality of the light coming through the lenses at night.
    I've tried a DA polisher with a hard pad and a cutting compound, this helped but not enough.
    Any ideas?
    kite's Avatar
    Oct 2007
    East Berks
    660
    Megs do a headlight lens cleaning kit.
    A4 (b6) 2.5 TDi QS Saloon.
    1,887
    Wet sand and machine polish. Have a look on YouTube loads of good how to videos
    drmole's Avatar
    Apr 2010
    Mountain Ash, Rhondda Cynon Taff, United Kingdom
    1,564
    ^^^^^ AS ABOVE ^^^^^^
    best way to sort them will be doing mine at some point too
    My A4 Detailed and finished with Zymol Glasur
    http://www.audi-sport.net/vb/detaili...ol-glasur.html
    A4 S-Line SE 220BHp with full Black pack With black badge (rear one still to fit) two tone Leather, Bose, phone prep in centre arm rest, IPOD conection RS4 pedals suede gear knob handbrake and steering wheel R8 oil Cap
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    I done this to mine...
    I had read several tutorials and write ups on refurbishing plastic headlights most of which involve using wet and dry sandpaper first followed by a machine polish... sounded easy enough but sanding the headlight with wet and dry scared the life out of me but decided to give it a go...
    Here's the kit I used...
    As you can see from this pic the headlight is fairly rough...
    ...still a bit worried about sanding the whole light so tried it on a small patch in the corner... used 2000 w&d with water of course then went over twice with Menz final finish which resulted in...
    ...happy with that I proceeded to mask up around the light and sanded the whole light face with 2000 w&d...
    ...ended up looking like this...
    ...dried off the water and finished up doing 3 passes with a soft pad an Menz final finish..
    ...the result of the first pass...
    ...and the final result...
    ...compared to the passenger side that I haven't done yet...
    ...and finally a comparison with the headlights on...
    Before....
    After...
    Happy with the results of that but felt it needed a little more effort so had another go another day...
    Did a few more passes over the drivers side headlight as I wasn't completely happy with the final finish...
    The result of 3 more passes over with Menz final finish and a spot pad on a Kestral DA...
    Looking at this one compared to the passenger side one I decided I couldn't wait and cracked on with sorting that one out too... feeling more confident of my abilities now I went straight in with 1000 grit wet and dry which took a bit of work to get an even finish then worked the light over with 2000 grit wet and dry as before....
    This is the point where you would justifiably feel sick as a pig looking at the very opaque headlight.... Just to reassure you I taped up half the light and did a single pass with the DA...
    ...as you can see its pretty easy to get the finish back but use a hardish pad as my medium pad had got saturated and ended up using a soft pad which took god knows how many passes until I was happy...
    Reminder of the light before..
    ..and after...
    Next thing to do is to get some the Lamin-x film to protect the headlights now the UV layer has been removed and to help protect against stone chips...
    <tuffty/>
    drmole's Avatar
    Apr 2010
    1,564
    Great write Paul definitly going give this a go on mine they not as discolored but really rough n stone chipped
    Jul 2006
    324
    cracking job should be referred to the "how to" section.
    Jul 2006
    Kingston upon Hull, United Kingdom
    178
    Impressed - definatley gonna try that one !!!!
    During a 4 wheel drift on the M25 i hear from my mate "Dont you ever do that again! Gimme the keys" after 12 hours of owning my old S4
  1. alloy wheels DULL?
    By philip.levis in forum Detailing
    Last Post: 13th June 2011, 09:40
  2. xenons gone dull
    By mattys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2008, 12:48
  3. Dull White Paintwork
    By axelfols in forum Detailing
    Last Post: 11th April 2008, 13:13
  4. Dull "Hmmmm" sound on cold S4
    By imported_DrOdius in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2004, 16:23
  5. Dull
    By Just Plain Old in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2004, 20:20
