    Oct 2011
    multi function steering wheel question
    Hi all just brought a 05 A4 Sline with the sat nav plus stereo in it it doesnt have the multi function streing wheel in it is this easy to fit or does it involve lots of wiring
    cheers john
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Not too much from what I've seen.
    Do a search.
    Basically you need the MFSW, new steering ring, controller, and harness.
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    Get in touch with NHN on here, he's done loads and will come up with a good price for you, especially if you're in the South
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    You need a Midline/Highline Steering ECU, unless you're looking at an extra £150 for the ECU that will accept MFSW.
    Do you have Cruise Control? If so then you have the required ECU already and all that is needed is the wheel itself and an Airbag harness with the MF plug. If you have a DSG box then you already have the required ECU and Wiring loom and you'll only need the wheel!
    All of the above scenarios with require coding with VCDS also.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
  1. Multi-function Steering Wheel
    By White220 in forum General Technical / How To
    Last Post: 15th September 2007, 20:11
  2. A3/S3 multi-function steering wheel
    By 4SilverRings in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2006, 05:18
  3. Multi Function Steering Wheel
    By maz1975 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2006, 15:26
  4. Multi Function Steering Wheel
    By ldw in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2006, 11:54
