Volks AutosAH Fabrications
    kashiskash's Avatar
    Jan 2009
    34
    tip/tronic or manual pro's and con's
    well it will soon be time to sell my current Audi A4 TDI Avant to upgrade for another one.
    Before owning this car I was an avid BMW fan having owned 5 of them in the past.
    The car I had before my Audi A4 was the BMW 325i tip/tronic(auto) and that was an exellent drive so I was wondering how the 2.0 TDI multitronics are, as to the manuals?
    Avantageous
    Apr 2010
    Hampshire
    337
    Audi Multitronics are notorious for a juddery pull away (I had one). Get a tiptronic quattro and its amazing (now what I have).
    kashiskash's Avatar
    Jan 2009
    34
    Thinking about the 2.0 tdi 143psi engine tiptronic is this a recommended combonation
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    This was my first Multitronic and it's smooth as silk and doesn't have the juddery pull away, but to be honest I heard it's not the most reliable box (I've had no problems touch wood) but if I was you I'd go manual if thats what your used to. Drive it normally and it will steady pull to 80 and only kiss 2000rpm. Floor it in S mode it takes off with a slight turbo lag and will keep pulling till you run out of road or usually the next set of lights but it will start drinking like a piss head on new years.
  1. VVT, what are the pro's/con's?
    By aragorn in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2010, 11:25
  2. Decat'ing S3 pro's and con's??
    By Rob_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2010, 12:15
  3. Pro's and con's to fitting the dump valve to the cold side?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2009, 12:29
  4. A3 cabriolet pro's and con's
    By chiefwiggumpi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2009, 20:34
  5. Pro's & Con's For Leasing of cars
    By neversaydie in forum General Chat
    Last Post: 24th June 2005, 15:07
