    90
    quick DIS retro fit question
    i just bought cruise control / DIS stalks for my 2005 A4. my indy has vagcom and so will be able to code them for me. im just concerned that when the DIS stalk is installed that i will get the error for the empty washer fluid. do i need to but the wire from audi to stop this error, or will my indy be able to ground it and delete the error without me buying anything else?! cheers.
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    Any wire can be used to ground the pin. Do a search, think its pin 1 on the blue multi connector behind the instruments.
    Chris
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    The sensor and seal is only £10 from the dealer, while you've got the cluster out, you may aswell do it.
    I did the retrofit (c/c and DIS) a few months ago, any questions, feel free to PM.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
  1. Retro fit DIS
    By StompOn in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th July 2011, 18:38
  2. Full DIS Retro fit?
    By Bigman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th July 2010, 15:59
  3. DIS Retro-fit Question
    By NickR85 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2009, 16:49
  4. Retro fit DIS
    By chrisru in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th October 2007, 09:08
  5. DIS Retro Fit??
    By ashminors in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st October 2004, 22:01
