Monster MotorsportChris Nott
    Hucknall, Nottinghamshire
    17
    Question Door handle cover 2005 B7 A4
    Hi I have a 2005 A4 Avant. Yesterday I went to get in it and the door handle cover came off in my hand. I have tried to put it back on again, but it won't stay on despite the fact I can't see that anything has broken off. I have seen many A3 and A4's with door handle covers missing, so am guessing that this has been a common fault. Can anyone help?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    have a close look you will see a silver bit at the top
    theres 2 notches that the cover fits on look at both you will see
    well the silver part slides across
    you need to put cover on pull handle as tho you are opening the door
    and get a credit card and slide the silver bit towards the back of the car
    if you post a pic ill point out the part
    17
    All sorted, thanks!!!
  1. Door Handle Cover Re-fitting
    By Kryten1967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th August 2012, 10:11
  2. Exterior door handle cover part number please!
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2011, 17:23
  3. drivers side door handle cover rattle
    By felixtcat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2010, 10:07
  4. Door Handle Cover!!
    By disco_stu01 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd November 2006, 14:02
  5. Loose Drivers door handle cover
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st June 2005, 21:05
