EM TuningJMB Retrofits
    Sep 2011
    south yorkshire
    30
    Exclamation 2.0 tdi cab battery light flickering then cuts out under hard driving!!!
    hey!
    ive had my car a few month and every now and again the battery light flickers mostly when driving it hard. so yesterday i really pushed the car and bang it just cut off like someone had disconnected the battery??? then a split second later came back on n carried on driving but i noticed everything had been reset, the clock,the computer but the stereo settings was still ok. anyone else had this problem am thinking it could be the alternator cause its only just had a new battery so can be that.
    slepy's Avatar
    Sep 2009
    Sheffield
    1,128
    Had something similar in a focus and it was faulty alternator but first check battery terminals if they both hold properly.
    2,159
    I would start with the alternator & battery, also a scan with vcds could help with fault finding.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    It could be the belt slipping, check the tension and that it's clean and grease free.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
  1. PAS gets very hard after a bit of driving!
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2010, 20:54
  2. Battery light keeps flickering on dash????
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2009, 21:16
  3. Please help reverse light flickering
    By benr in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2008, 17:06
  4. First beam light flickering
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2006, 18:27
  5. Hard Driving!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2005, 02:08
