Volks AutosJMB Retrofits
Results 1 to 10 of 10
    21
    Fitting PARROT MKi9200 to RNS System - anyone done this?
    Hi folks.
    Have decided to install the Parrot MKi9200 Bluetooth Handsfreeto my RNS-E system after much deliberation. On rummaging around the net I would have thought it would be straight forward however any tips or advice would be very welcome before I venture forth. Otherwise Halfords charge £24.99 which I must admist is not bad!
    Cheers,...
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Moby Dick View Post
    Hi folks.
    Cheers,...
    I can't help you with the self-install, I'm afraid, but what I would say is that if you do decide to pay someone to fit it, don't whatever you do go to Halfords. Go to a proper independent specialist ICE fitter.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    21
    Cheers for the advice Jeff. I can understand your reluctance with Halfords!!!!! Decision based on £150 fitting from a specialist and £24.99 at Halfords. Big difference!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    I know, and there's a reason for that. Ever heard the expression "buy cheap, buy twice"? You'll pay Halfords £24.99 to do it bady, then pay a specialist £150 to re-do it properly.
    unikarl's Avatar
    Mar 2004
    374
    I was told by numerous places that the MKI 9200 wont work properly in our A4's because they are not compatible with the amp that truns the rear speakers so any music you listen to through it will only come through the fronts.
    2.0 TDI S line.
    Cruise, Leather, DIS, RNS-E, autodim, MFSW, ambient lights, Bi xenons.
    Gone to its new home
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    435
    I had this kit fitted to my Mk1 TT and had to get an expensive loom to allow it to work with the Audi setup. I would contact a company called Justcarkits, the bloke knows his stuff. I still have the loom if ya need one, it cost all together about £100- 150. I no longer need it so will be happy to sell it on. Pm me if u need it
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    itsmeagain's Avatar
    Mar 2010
    West Midlands
    435
    Just read your post again, actually you would be better off just buying the OEM Bluetooth module for your RNS-E. And just sell the Parrot kit.
    21
    Cheers Itsmeagain.
    Have been in touch with a few specialist installers and the information varies enormously! However yes I need the cable to convert the rear speakers to audio and best price fitted is £287 fitted all in. However phoned them yesterday to book the car in and the guy will come to my home. Guess what, still waiting to hear... Will give him till 5pm tomorrow then find someone else.
    I run an HTC phone which has absolutly rubbish battery life so with the Parrott I can leave in in the glove box plugged in the USB on charge use the bluetooth for music and phone. Audi plug in not sure you can use USB plus this is still cheaper!
    Cheers for the offer of the cable and if needed will certainly PM you. Did you fit the kit yourself to your TT?
    21
    Quote Originally Posted by unikarl View Post
    Absolutley correct. Stupid isn't it.
    itsmeagain's Avatar
    Mar 2010
    West Midlands
    435
    I got mine fitted from Justcarkits, I drove to there premises and the bloke fitted it. Top bloke. The lead that I have enables it all to work thru the audi amp.
  1. Fitting Parrot Mki9200
    By joe.c in forum General Technical / How To
    Last Post: 5th January 2014, 11:22
  2. Bose system and parrot mki9200 handsfree kit
    By JDM82 in forum In-Car Entertainment
    Last Post: 12th September 2011, 21:34
  3. Parrot Mki9200 fitting - help!
    By boulto232 in forum General Technical / How To
    Last Post: 29th April 2010, 16:32
  4. Fitting Parrot Mki9200 Help!
    By boulto232 in forum In-Car Entertainment
    Last Post: 27th November 2009, 13:28
  5. Fitting Parrot Mki9200 - Help!
    By boulto232 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2009, 22:48
