Fault Code - P2181: Any ideas?
Brendan12
Birmingham
Hi, I scanned my car and it came up with this fault code. Can anyone shed any light on what it might be?
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E35A499120 Mileage: 89030km/55320miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 J HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 0080
Revision: --H02--- Serial number:
Coding: 0104000318070020
Shop #: WSC 00586 210 88211
VCID: 2854E424E275
1 Fault Found:
008577 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 88905 km
Time Indication: 0
Freeze Frame:
RPM: 2814 /min
Load: 48.2 %
Speed: 63.0 km/h
Temperature: 73.0°C
Temperature: 16.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
strange how? taking longer to warm up? over heating?
this fault often flags up if the indicant engine temp and dash temp are substancially different.
It never seems to get to temperature, unless it gets a bit of stick. All heaters are fine though so I presume its the stat or temperature sensor.
The error code shows a single fault frequency, but the "Implausible Signal" fault can only be generated by the the sensor. Get that changed first and if your still not getting upto temp then change the stat.
Oh ok yeah I will try that first. Thanks!
