Volks AutosMonster Motorsport
Page 9 of 12 FirstFirst ... 23456789101112 LastLast
Results 321 to 360 of 457
Like Tree72Likes
Thread: Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
  1. #321
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    317
    Quote Originally Posted by jimrob View Post
    I did not mark the bell when I removed it. I'm heading out right now to switch it around. I will post what happens afterwards.
    Thanks,
    I bet you any money that your next post will be saying the the roof is working
  3. #322
    Aug 2013
    MA. USA
    11
    Quote Originally Posted by VagPro View Post
    I pulled the motor unit out again and matched it up with your pictures. It is the same with the wire leads coming out of the motor at the bottom. Now I'm stumped. I was hoping that was the problem.
  4. #323
    Feb 2011
    317
    You shouldn't have to takeout the motor off the hydraulic block, just the two long 7mm head bolts and the bell housing will come off. Then turn out 180 degrees....
  5. #324
    Aug 2013
    MA. USA
    11
    Ok, I did take the bell off the hydraulic base and re-installed it. I put the back end of the motor back on and it works now. Maybe I did rotate it 180 degrees, I'm not sue as I did not mark that part. I thought you meant the larger bell of the hydraulic unit. Inside the outer motor cover are only two magnets and they both look identical. Why would that make a difference as to which way it goes on? I've worked on plenty of wiper motors, starter motors and all kinds of other 12 volt motors since the early 1970's and never heard of this before. All I know is that it worked 4 times in a row for me without any hesitation and I am happier than all you know what. Thanks, Jim
    PS, I know where I goofed on the bell housing. I'm used to using that phrase for the end of the motor where it attaches to a pump or whatever.
  6. #325
    Feb 2011
    317
    Glad you got it sorted
    When the bell housing (motor cover that holds the magnets) is on 180 degrees out it causes the motor to run backwards, hence it reverse pressurises the system. :-/
    Must be because turning the bell housing switches the magnet poles.
  7. #326
    Aug 2013
    7
    Hi Krumz from sunny Cyprus
    thanks for all detailed explanations. I had same problem, hood opened few inches and stops. I done all the steps and the motor start to work again. here in cyprus, the cost of the maintance probably much more than the uk. so thank you again for helping me save thousands of euros. But i have another problem, now, the hood unlacth, moves up, rear part up, trunk component open then stop. I still heard the voice of motor but the hood doesnt go in and complete the roof open. When i help the hood to open completely, hood closed up with no problem. I tried to ignition on and do it manualy 3 times suggest but it didnt solve the problem. I dont have a software to seen if there is any faut in the car by the way.
    thanks in advance
  8. #327
    Aug 2013
    MA. USA
    11
    Now I understand. So originally when I cleaned the armature I must have put it back on 180 degrees off. This time it went back on the right way. I'll remember that in the future.
  9. #328
    Feb 2011
    317
    Quote Originally Posted by Sualp View Post
    thanks in advance
    Hi, did you mark the motor bell hosing when you took it off ?
  10. #329
    Aug 2013
    7
    Yes i did. I dont know if it is important but I also took it off the bottom part aswell for check if the components are in good order and didnt mark it.
  11. #330
    Feb 2011
    317
    Sorry mate, did you or did you not mark the bell housing? If it is 180 degrees out you could have the problem I believe you are explaining
  12. #331
    Aug 2013
    7
    Sorry, the body which have 7mm bolts, yes i did like you described. I also took off small 2 bolts in the bottom part and check inside. When i did it, i didnt mark that part. Sory again, i am not good at mechanical stuff so i dont know what is the bell housing.
  13. #332
    Feb 2011
    317
    The part held in place with the two long 7mm bolts is what I am calling the bell housing. If you have marked it and you are 100% sure it's on the right way then you need to get a vcds cable.
    Also post me a video of the fault please
  14. #333
    Aug 2013
    7
    Yes i done each of the steps properly, so i m sure 100%. I have already ordered the vcds and will expect to get in next week. Where do you prefer to i will send the video? Thanks all your help again mate
  15. #334
    Feb 2011
    317
    No problem at all mate, post it on YouTube and put the link on here...
  16. #335
    Aug 2013
    7
    Hi Krumz, you can see the video on Audi A4 2007 model roof problem - YouTube
    Roof getting worse today. Yesterday when I closed the roof, the trunk component opened with no help but today, as you seen on the video, I help the trunk component to open.
    Feb 2011
    317
    Only thing I can think to check without a vcds check is to make sure that none of the hydraulic hoses are trapped anywhere. Also I assume you have already checked the fluid level?
    Bit of history check .... Before you did the motor repair, the roof used to lift a couple of inches with no motor noise, after you did the motor clean, the motor works but not the roof gets stuck?
    So basically the roof worked fine prior to the motor stopping working and doing the clean ?
  18. #337
    Aug 2013
    7
    yes the roof worked fine before the motor stop
    ehm i didnt check the fluid level but when i took the motor out i saw there is enough fluid in. Is tere any level indicated to show min level of fluid?
    i am not sure about if the hydralic hoses are tapped anywhere. What i m sure is, i couldnt put it back boot trim so the storage box is not moving easly. I guess i need to the the motor out again, check the fluid level and trying to open it when the motor is out. What do you think?
  19. #338
    Feb 2011
    317
    Ok, there is a level indicator on the fluid reservoir, unless you have a leak the fluid level should be fine. Yes definitely check if any of the hoses are trapped in particular under the bolts for the hydraulic motor assembly. Also what is wrong in the storage compartment, that could also be impeding the movement of the roof.
    Firstly check what's up with the storage compartment, then make sure everything is put back correctly. Something's wrong somewhere.... If you are 100% sure everything went back correctly then next step is Vagcom scan.
  20. #339
    Aug 2013
    7
    i just checked and the fluid evel is fine, and i tried while the motor out in the place. All the hoses were free while the motor is out. Nothing is changed.
    Storage componet doesnt fully move up (close up) anymore. When i put the storage component up my hand, it fall down in half way. But when it is opened, its not problem. So i dont think it is related with roof fault but i dont have any experties to surely say.
    so, i gor for the last option and already bought the pirot one i guess from amazon uk. I hope i will give you better accurate information while i get it. Thanks again mate
    VagPro likes this.
  21. #340
    Aug 2013
    London
    Hello fellow enthusiasts,
    I recently purchased an Audi A4 2007 cabriolet, with faulty roof.
    I experienced the same issues as yourself, roof light flashes 10 times, pops open then goes no further. I tried a manual reset as did the local VW audi guys, with no luck. VCDS showed no faults at the garage and they asked me to take it back next week so they could have another look. They reckon it might be the storage shelf as it does close fully (I think the cable is damaged but its in the fully open position and doesn't show any errors in dash. When i leave the storage latch/bar to closed position it does show in dash.
    So today i followed your instructions including the marks and removed motor, cleaned up and replaced but no difference at all. What i did notice was that the 3 aluminum cylinders adjacent to the motor were very hot, could this be where i had repeatedly tried to open/close the roof?
    I then got a multimeter (set it to 20V) and then connected it prior to where the wires enter the motor housing, it showed as NEG zero. I then closed the boot lid and operated the roof switch and the reading increased to 12.9V. Does this mean that power is being delivered to the unit but its not operating?? I could not hear any motor type noise throughout.
    I'm really confused as the stealers want £100 and the local audi specialist wants to strip open the storage area and rebuild it as they think this is where the problem lies.
    I tried VCDS and found no faults prior to repair attempt, nor did the audi specialist however after my attempt i did get these following codes:
    3 Faults Found
    02000 - Switch Position
    008 - Implausible Signal - Intermittent
    03245 - Canopy Position Implausible
    01997 - Convertible Top Locking Motor (V223)
    011 - Open Circuit - Intermittent
    Any suggestions??
  22. #341
    Feb 2011
    317
    Quote Originally Posted by d33p View Post
    3 Faults Found
    Any suggestions??
    Hello,
    Great bit of diagnosis, yes it does mean that the motor is getting power and your should be hearing a motor noise. Did you check the brushes are free to move in the carriers?
  23. #342
    Aug 2013
    London
    Wow, that was a super quick response! Thanks...
    Sorry, i did push back both sides with the tip of my stanley blade and one of them sprung back out whilst the other did not pop back out again, i tried to free it but no luck so i pushed it back to original position. Im quite sure they were both touching.
    Also, i used wet and dry 600 which was slightly more coarse and then followed by wd40 on the end of a cotton bud to remove any debris, there was lots of grime that was removed as a result. Hope that didn't cause any damage?
    Is there any sure way of telling that the problem is in the motor?
    Hello,
  24. #343
    Feb 2011
    317
    Haha I aim to please
    I don't think you've done any damage at all, but the brushes should spring back and if you had to push one back against the commutator that is the problem, it needs to be constantly pressed against the commutator to work.
    Pry open the brush carriers, make sure they spring back under the force of the spring and it should be fine.
    In response to the other questions, yes the metal solenoids do get hot, don't worry about the fault codes yet as manual operation does register some codes.
  25. #344
    Aug 2013
    London
    Ok,will try your suggestion tomorrow and see how i get on....
    If that fails, is there anything else it could be?
  26. #345
    Feb 2011
    317
    I'm 100% sure it is the sticking brush. The fact that you've tested it with a multimeter proves that the motor is at fault. I'm assuming the motor is not burnt out (which I have not come across yet !)
    Worst case, new motor is 180+ from the dealers on trade
  27. #346
    Aug 2013
    London
    Hi again, how do I pry open the brushes?
    from which side do I insert the screwdriver?
    sorry to ask such a basic question but want to get it right first time before I break it?!
  28. #347
    Feb 2011
    317
    If I say pry open the brush carriers (they are the brass rectangular tubes which have a slot down one side for the copper cable) does that make more sense ?
    There is a photo on the first page with an arrow in where to insert a screwdriver and pry them open
  29. #348
    Aug 2013
    London
    Krumz! You are the man!
    I reopened the motor and inserted a screwdriver like you said and twisted it so the brush suddenly popped out. Now both brushes are correctly touching the commutator and no longer sticking when pulled back.
    I reassembled everything and hey presto, it worked!! After many months of no roof operation (the previous owners didn't want to go down the road of fixing it!) it worked just like that with no hesitation. Needs a good clean though.
    Thanks very much mate, i'm so grateful for the thread and your advice.
    All the best!
    Deep
    VagPro likes this.
  30. #349
    Aug 2013
    Quote Originally Posted by iscurtis View Post
    Last year, the roof started to act up on my wife's 2007 A4 cabrio about 2 weeks after the warranty expired, no joy with Audi who refered me back to the dealer. Car went to workshop to get checked out and 1 hour and £105 later they hit me with the news that the hydraulic pump had packed up and this will cost £1,800 to fix! I believe the pump itself was around £1,200 and the rest was labour and sundries.
    After trawling the web I found my problem was very common, the hood lifting maybe 2" above the windscreen and no more, no noise from the boot where the pump is. Sometimes the hood would open fine, but then will not close, it would not go any further than opening the cover. So the motor in the pump is not turning.
    Took the motor cover off and cleaned the copper moving part and made the brushes move and all was good, great! Had to do it again after a few operations, then again and again. I got on to the dealer parts and asked them if I can buy a motor without the pump and they said it was not possible. They are available to the trade apparently at around the £200 mark.
    By now Wife is not speaking to me and started to look again on internet for ideas, she found Mervin on eBay (username is Autoelectron) and we got in touch and decided to have a drive up to see him in Yorkshire, its a 200 mile drive for us, but the temptation is that he promised a lasting solution for £95.00 and give a years warranty on the motor. He checked the computer and changed the motor and tested the roof several times. I think its faster too!! We have used it probably 50 times since repair, no issues. So, I could have saved all the messing about in the first place and got it fixed for less than Audi charged me for their so-called diagnosis, its a no brainer.
    I have written to Audi to seek their comments on the roof issue as its a very common fault, Mervin said he had recondioned just over 250 last year and is doing 8 a week this year.
    Iain
    I had the same problem with my A4 cab 2008. Audi quoted much the same figure, then I looked on these forums and saw several comments about Mervyn and how brilliant he is with this problem. I rang him first, he assured me he could fix the problem, said he has done loads so we made an appointment one Saturday and drove to Harragate. We dropped the car off at Mervyns unit and took the train into the town whist the car was fixed. Mervyn rang after a couple of hours, the car was ready. Sine then we have told several people about Mervyn, my boss has been to see him too. It's well worth the trip and saved us hundreds. I even keep a note of his number etc in my car should any one ever ask me about my roof as this is a big problem it seems with this car between the 2002 and 2009 models. Audi really should do something about this, how dare they charge so much, how can they justify this when Mervyn can fix so easily and cheaply. Please anyone with the same problem don't hesitate to use Mervyn. You can google him like I did or search through eBay. I would like to know how only one man is able to do this, I reckon he has the market cornered.
    Miss M.
  31. #350
    Feb 2011
    317
    Quote Originally Posted by Miss Marples View Post
    Miss M.
    Hi Miss Marples,
    Yes Mervyn is really good and a very nice person too! However the issue with the roofs is simply the brushes sticking in the carrier, unfortunately most people clean the brushes and don't bother to resolve the sticking issue and have the problem again. Provided the guide is followed correctly the issue will not reoccur.
  32. #351
    Jul 2013
    7
    Hi there,
    I'm having a problem with my A4. With the roof open, when trying to close it just opens the lid a few inches (2 max) and does not do anything more. When closed some times it opens correctly and some times don't but allways unlatches the roof. I've found out that when the roof is unlatched and not opening correclty, if i lift the front of the soft top while pressing the close position button, it at a certain point starts making pressure on the roof to close it, and after that if I try to open it it opens ok. Do you think it is because of the engine and is the same problem reported in the topic?
    Anyway, I can't remove the rear panel cross trim... Tryed lots of times but i'm affraid of get something broken. Can't anyone upload a video of how to do it (or even the all process)?
    It would be perfect for newbies like me to learn how to do it.
    Thanks in advance for everything.
  33. #352
    Feb 2011
    317
    Quote Originally Posted by joaopedr View Post
    Hi there,
    On the guide there are links to the workshop manual. Download them and check
  34. #353
    Jul 2013
    7
    I've read those pdfs but still can't do it...
    Does the simptoms i have described seem to be the same off yours? Do you think this will solve it or does it seem to be the position sensor? Thanks
  35. #354
    Feb 2011
    317
    I don't quiet understand what you are explaining on the roof operating, but in summary if it opens a couple of inches and you don't hear any whirring noises then its the motor.
    You have to apply a bit if force to take out the cover. Remove the two clips and pull it in the direction shown in the guide. Alternatively are you in the leicester area ? I offer a 12 month warranty on the repair....
  36. #355
    Feb 2013
    I think it's your roof motor brushes sticking in the brass housings or a dirty commutator, the boot plastic cover comes off if you pull it upwards, it just clips off, mine was tight but came off ok.
  37. #356
    Apr 2010
    Dear VagPro, brilliant write up. Had exactly this problem on Tuesday. Searched the net and found your post. Absolutely spot on. Took about 2 hours in total and no hitches along the way. I could see where one of the brushes was sticking in the holder. Slight tweak with a screwdriver and all is well. Thank you so much, couldn't have done this without your fab post.
  38. #357
    Aug 2013
    Blocked door seal to blame
    Quote Originally Posted by Michael Clarke View Post
    looking for some help with leak from Cabriolet roof. Water coming in at front driver's side corner where it meets the door post. Checked that roof is properly locking and lubricated latches. Is there anything anyone can suggest?
    This is caused by a blockage of the drain holes in the door seal. The seal then backfills with rainwater, eventually overflowing back on the interior side of the seal and into the sill/footwell area. Easily spotted, as you can feel/hear the seal is full of water by running your finger along it.
    Solution: Simply clear the drain holes on the lower edge of the door seal ( you'll have to lift it up as the holes are concealed on the bottom edge ).
    Usually caused by road grit thrown up by the front wheels penetrating through the lower edge of the door.
    Sometimes the problem goes a bit deeper. The door seal actually has an inner and outer component - a seal within a seal. On occasion the inner seal can also become blocked with grit. You then need to take a sharp point, and going ( carefully!) through the drain hole in the outer seal, punch a hole in the inner seal. This will then allow trapped water to escape the inner seal into the outer seal and thence the drain holes. You can speed up this process by 'milking' the seal i.e. running your finger from the top end of the door seal to the bottom towards the drain holes. It helps if you do this from both ends simultaneously.
    You will find a lot of dirt/grit in the water expelled through the drain holes.
    ....... Problem solved.
  39. #358
    Oct 2008
    9
    Question: Possible fluid leak?
    Hi, my A4 B7 seems to be suffering from the same problem. I've just been following your awesome instructions to get to the motor. I've got access to it but have noticed theres a residue in the bay below it. Am wondering if perhaps some of the hydraulic fluid has leaked at some point (it looks sticky / dried rather than fluid). Shown in attached photo.
    The reservoir has fluid in it, I'd say approx 1/3 full, its below the Min level indicated on the reverse side of it. Should I top it up? What should I use to top it up with?
    Any tips or advice gratefully received!
    Mark
  40. #359
    Oct 2008
    9
    I had the same thing on my previous B6 Cab. As Willf92 said - it's caused by grit / debris blocking the drains. I used a straightened coat hanger inserted at the top of the drains and threaded it down, then tested it with water through a funnel. A load of crap flushed out and then the water whooshed through - was fine afterwards. :-)
  41. #360
    Oct 2008
    9
    Quote Originally Posted by markhaines View Post
    Mark
    Just reading round the net - it seems that I need to measure it with the roof down not up - so perhaps this explains it. The residue is still a little concerning though, unless it's been serviced previously and someone 'missed' when topping it up?
  1. Audi A4 Cabriolet Hood Problem
    By vaslam1986 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2010, 01:58
  2. Audi Cabriolet - Manual Hood Problem
    By AllDubbedUp in forum Classic Audi Forum
    Last Post: 21st February 2008, 08:50
  3. Cleaning/Protecting Soft Top Roof...?
    By Katherine B in forum Detailing
    Last Post: 7th March 2007, 10:18
  4. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
