Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 281 to 320 of 454
Like Tree71Likes
Thread: Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
  1. #281
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    311
    Quote Originally Posted by pez5918 View Post
    Suggestions please , sorry if its been asked previously but I've got gremlins in my roof. Initially stopped half up , manually opened fully, found it would not operate to close at all , closed manually then found it now opens the classic inch or so at the front . The rear motor was silent so tried your advice and cleaned the motor brushes remembering all you said , All reassembled and now I can hear the rear motor kick into life but roof will still only open an inch up front , I have noticed the manual method is not how it should be in that the red key is near on impossible to turn , any more pressure it would snap in the rear key hole , wondering if the mechanism may be seized and causing this or am I barking up the wrong tree , I'm no mechanic btw lol
    Did you mark the housing before you took it off, making sure it goes back the right way?
  3. #282
    Jun 2013
    A4 Roof now working after following VagPro's initial Instructions
    Quote Originally Posted by VagPro View Post
    Thanks VagPro, I've been putting up with an intermittent roof opening/closing for 6 months until I came across your very clear instructions/photos re cleaning Motor Commutator etc. In fact hardest part was replacing the side panel and alligning the grommet holes etc.
    Thanks again
    VagPro likes this.
  4. #283
    Jun 2013
    Staffordshire
    9
    Hi , yes housing marked up , noticed today when taken manually down it will raise on auto an inch then stop also same as front,motor still audible at rear
  5. #284
    Feb 2011
    311
    Hmm that's interesting, was the motor audible before you cleaned the commutator ?
    what fault codes are you getting ?
  6. #285
    Jun 2013
    Ok, so in my rush, I skipped the brush prying and spring action check. So, I get the roof working and I think life is great. Just saved $650 from Audi of Tysons, VA. They quoted new motor. This after passing the 50K and 48 months by 2 mos. and 100 miles. They offered $100 off the new motor and nothing on labor.
    Long story short, the motor worked great for 3 weeks, and then fail. Repeated the cleaning (used rubbing alcohol too) and nothing. Checked the brushes, and I am sitting pretty.
    Now if I could only find a cheap VAG COM cable for my 09 a4 cab. Any ideas? Love to be able to write so I can activate my AUX on the symphony II+.
  7. #286
    Feb 2011
    311
    Quote Originally Posted by nedfp View Post
    you are "sitting pretty" ? Is the roof not working ? Make sure the brushes are making contact with the commutator. You HAVE to pry open the brush carriers
    vagcom cables eBay or NHN on the forum
  8. #287
    Jun 2013
    Staffordshire
    9
    No the motor was inaudible till a good clean , now audible and will raise the rear in auto to close but stops after an inch , I'm thinking maybe hydraulics ? Not got fault codes as yet as no cable etc , trying to obtain one or take a trip to local garage
  9. #288
    Jun 2013
    Sitting pretty = the roof operates as expected. The issue has been resolved. The point of the reply was to stress that in my haste to complete the cleaning, I did not check the brushes. It was the culprit. I am admitting to my stupidity so that others may learn that the brush checking is vital to the DIY.
    I am do wonder if I should have added a lubricant to the brushes though.
    A friend who lives next door, who is a chemist for Mobil, gave me some "product" (red lithium grease) for the top of the spindle as suggested. Also allowed we to sample some M1 0w-40 for my next oil change. Shame, I just did my first extraction last weekend (mityvac 7201) and refilled with Rotella T6 5w-40. Off topic - I know.
    I did get a cheap K+CAN cable from ebay. Can't verify it works as VAG Commander and VCDS do not recognize it. I guess I need to do more research/buy another. I bought a Bluetooth elm-327 reader that works great, just can't write.
    VagPro likes this.
  10. #289
    Jun 2013
    Staffordshire
    9
    Managed to aquire a Bluetooth code reader thingy which is reading no faults , I know it works because its picking up one on the wife's A3 so still stuck
  11. #290
    Jun 2013
    Ended up getting a true Ross-Tech VAG COM scan. Had 2 codes for the roof cleared:
    02000 - Switch Position
    008 - Implausible Signal
    Went on 40 mile top down cruise in sunny 85 degree weather. The joy of owning a Cabriolet!
    Aux is now work - I'll post the wiki.
  12. #291
    Feb 2011
    311
    happy days, don't worry about those codes they won't come back as they get generated after manual operation
  13. #292
    Feb 2011
    311
    No codes..... Hmmmm can you access the roof module from your code reader ? Is it using the same protocol as vcds or is it a generic obd2 reader ?
    Is your wife's a3 a cabriolet ? And can you acess the roof module using your reader ?
  14. #293
    Jun 2013
    Staffordshire
    9
    Its a generic obd2 reader , the wife's is not a cabriolet , going to have another play , how you fixed Fri for a visit lol
  15. #294
    Feb 2011
    311
    you need vcds, you can't access the roof module with obd2. Available in the evening....
  16. #295
    Jun 2013
    Staffordshire
    9
    Think ill pay you that visit before I tear the rest of my hair out , how you fixed wed eve ?
  17. #296
    Feb 2011
    311
    Lol no problem at all, I'm busy wed. Does today work?.. (Taken a day off from the office)
  18. #297
    Jun 2013
    Staffordshire
    9
    I'm in Staffordshire so a trip down the a50 and I can be with you in an hour if you Dnt mind
  19. #298
    Feb 2011
    311
    Perfect lets do it, phone number on my facebook page
    Facebook.com/vprouk
  20. #299
    Jun 2013
    Staffordshire
    9
    thank you again
    Would just like to say a massive thankyou to VAGPRO for the assistance , roof is now in perfect working order , and the trip to Leicester well worth it lol .
    Facebook.com/vprouk
  21. #300
    Jun 2013
    Brushes
    Quote Originally Posted by olbyrne View Post
    Thanks again
    Hi VagPro, After cleaning the Commutator etc as per your instructions the roof worked fine for a couple of weeks and then same issue as before ie roof raises an inch and stops. I cleaned the Commutator again and all works fine again though I suspect one of the brushes does not spring back as easily as the other brush.
    Any suggestions on how to loosen a brush to enable it to make contact with the Commutator on its own accord?
    Thanks again
    Ol
  22. #301
    Feb 2011
    311
    Thanks again
    Ol
    Hi Ol,
    Definitely got to be sticking brushes, you need to pry open the carriers to free them up. (Be gentle)
  23. #302
    May 2013
    VAG PRO -- Bristol Audi quoted £2,600 for a new hydraulic motor after reviewing my intermittently working roof. Other dealers said the problem was more likely the motor and quoted £370-£400. Following your excellent instructions the roof has now been working perfectly for 2 months. I think sticking brushes was the main fault and easing open the holders was probably made the difference. Thanks for saving me £2,600 and beware main dealers!
    VagPro likes this.
  24. #303
    Jul 2013
    Hi VagPro,
    Thanks for this guide, the motor was originally not making any sound when I came across this comprehensive repair procedure.
    Having followed the procedure the roof unlatches and I can NOW hear the motor but roof still fails to move any further.
    This appears to be the same issue as that experienced by pez5918 above. Is there a quick fix for this, I have access to vcds.
    Regards
  25. #304
    Feb 2011
    311
    Quote Originally Posted by 27mart View Post
    Hi VagPro,
    Regards
    Hello,
    Did you mark the rotor bell housing when you took it off and are sure you have put it on the same way?
  26. #305
    Jul 2013
    Hi. Erm I did not mark the housing cover. It can only be mounted in two positions in order for the bolt holes to line up. Do you think turning the housing cover 180 degrees will make a difference then?
  27. #306
    Feb 2011
    311
    I know turning the cover 180 degrees will make a very BIG difference
  28. #307
    Jul 2013
    Ok I will try that later. Thanks for the prompt reply by the way. Cheers
  29. #308
    Jul 2013
    Top marks vagpro. I have rotated the motor housing as suggested. Roof now operates up n down. Many thanks for this guide. :D
    VagPro likes this.
  30. #309
    Aug 2013
    Hi
    I too have probs with my roof and today booked it in at Audi they said maybe pump and cost £1800 for pump?.. My car is 2007 a4 may I ask as I also live in Leicester if you could probably check it for me happy to pay you. They charge £98 to diagnose and know its rip off place. Many thanks Kerry
  31. #310
    Feb 2011
    311
    Quote Originally Posted by Kjm2304 View Post
    Hi
    Hi Kerry. Responded to your pm. Regards
  32. #311
    Aug 2013
    Thanks message on this site? Can not see it?
    Kerry
  33. #312
    Aug 2013
    Cheers will ring you tomorrow
  34. #313
    Feb 2011
    311
    No problem, I'm a bit tied up in the morning so afternoon is fine. Otherwise fell free to call now if convenient.
    Regards
  35. #314
    May 2013
    Hi All,
    I have the same problem as most of you however I have cleaned the motor as above and still have issues.
    mine started when I took my roof down and my battery then died on my car (long period standing still) I managed to fit a new battery but my roof would then not come back up so I manually bought it up. What I did forget to do was lock the hood cover down and just fastened the front roof clips. Only on driving did I notice the noise and then locked the cover down.
    now I can retract the roof no problem but when I try and bring it up nothing happens period. Roof does not unclip, roof cover does not unclip and no noise from my motor.
    I've not checked any codes as of yet as I don't have access to the software.
    im going insane with this car as not only has this happened but my tcm has just started playing up....!
    thanks in advance for any help
  36. #315
    Feb 2011
    311
    Quote Originally Posted by Smithk77 View Post
    Hi All,
    Hi Smith,
    When you cleaned the commutator on the motor, did you check the brushes if they are moving freely? Also did you pry open the brush carriers ?
    In regards to the problem you have now, I think you already know that you need to get access to a VCDS cable and take it from there. Let me know when you have the fault codes...
  37. #316
    May 2013
    Hi Smith,
    Hi vagpro,
    yeah I pried open and done everything exactly as stated. Gotta get my car serviced so may ask them to check and give me the codes.
    I'm thinking of buying the cables from eBay for future help. My car is a 56 plate 2.0 fsi auto. What do I need to ensure the cables can do so it supports my car?
    cheers,
    kieren
  38. #317
    Aug 2013
    MA. USA
    11
    VagPro you are indeed a PRO at this and thanks for posting all this information up. Hopefully you can help me out with my 2007 Cabrio roof issue. My daughter had my car while I was away on vacation. She put the roof down and it wouldn't go back up. The lid would unlatch and that was all it would do. She went online and found out how to manually close it. When I got home the roof would unlatch and that was all. The motor was not running. I took it out and cleaned the armature and made sure the brushes were free. The motor works fine now. The roof only unlatches when open or closed. When closed it opens up just beyond the latches. The motor can be heard running and the second bar back starts pushing downwards towards the car instead of the front going upwards. I have cycled the roof manually open and closed with the key on to reset the switches. It still does the same thing. The roof indicator light flashes 10 times when the key is turned on. Do you know what this means? I do not have a VagCom setup. My nearest dealer is 15 miles from me and not liked very much by the average person because they raise the prices on parts over the MSRP of Audi. I wish you were 10 miles from me instead of my living across the pond in the US.
    Jim
  39. #318
    Feb 2011
    311
    Quote Originally Posted by jimrob View Post
    Jim
    Hello Jim,
    Thanks for the very informative post, always helps when I have all the information. Sir, you have got the rotor bell housing on 180 degrees out, did you mark it before you took it off?
    Regards
  40. #319
    Feb 2011
    311
    Hi vagpro,
    cheers,
    kieren
    Hi Kieren, not sure as I have the tulle version. but you can pm NHN on this forum as he's a retailer and will be able to shine some light on it.
  41. #320
    Aug 2013
    MA. USA
    11
    Hello Jim,
    Regards
    I did not mark the bell when I removed it. I'm heading out right now to switch it around. I will post what happens afterwards.
    Thanks,
  1. Audi A4 Cabriolet Hood Problem
    By vaslam1986 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th July 2010, 01:58
  2. Audi Cabriolet - Manual Hood Problem
    By AllDubbedUp in forum Classic Audi Forum
    Last Post: 21st February 2008, 08:50
  3. Cleaning/Protecting Soft Top Roof...?
    By Katherine B in forum Detailing
    Last Post: 7th March 2007, 10:18
  4. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
