Just wanted to check to see whether front bumpers are easily interchangeable, e.g will the saloon front bumper fit the cabrio? My A4 is a 3.0tdi s-line cabriolet and it has the less attractive SE front bumper fitted and I want to swap it! Thanks
I did consider doing something similar but I do think the other bumper is that bit nicer so its got to be done! I presume that it's pretty much a direct swap and other bits such as fogs do not need to be changed?
