EM TuningAH Fabrications
    Sep 2011
    south yorkshire
    30
    A4 CAB 2.0 TDI EGR HELP!!!
    Right heres the problem am a total newbie to 2.0 tdi's my engine code is a bpw ive drove half way round world today (slight overkill) to get egr delete pipe came to fit it and theres no chance whats so ever fitting it. only option i can see doing is to fit blanking plates on the inlet and exhaust manifolds put a hose connector inbetween the coolant hoses for the cooler so it bypasses remove the cooler and pipe work and map out the egr.
    all am asking is has anyone dont this to same type car? and if i map out the egr will the flap inside close causing no air/fuel goin to the car? ive took pics so hope it helps and am sorry if theres a thread on this already so please dont have a go am just a man in need of a solution cheers.
    Sep 2011
    south yorkshire
    30
    right update!! found out my engine is the old one its a 2.0 8v not the 16v so i need to get a old pd inlet manifold and egr delete pipe but this means losing my antishuder valve!! so am un decided what to do now anyone else done this would be appericated
    bert-a4's Avatar
    Jul 2010
    Bristol, UK
    72
    I too have a 2.0 tdi bpw on a cabriolet.. First dpf delete now this! Fml! Helppppp
    Sep 2011
    I had my EGR valve mapped out, but had to put a blanking plate in (Ebay) due to the valve flap being lodged open.
    At least it solved the problem!
    JayD's Avatar
    Nov 2012
    Bedfordshire
    16
    Did you guys ever find a delete kit for the BPW CAB?
