EM TuningVolks Autos
Results 1 to 11 of 11
    Stepho's Avatar
    Feb 2004
    Strathclyde
    444
    Brake Pad warning light on
    My Brake pad warning light has been flicking on and off now for a couple of weeks and now its more on than off, if you know what I mean. Had a good look round and all pads have plenty of meat on them. Had a go at shorting out but no joy. Any solutions to this? Is there a way of turning the light out on the dash?
    Thanks in Advance
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Check the connections to the calipers!
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Stepho's Avatar
    Feb 2004
    Strathclyde
    444
    been checked and all OK
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Check your brake fluid level
    All cars i've owned before have a sensor in the brake fluid reservoir to tell you when you're low....
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,994
    Did you check both innner and outer pads or just looked at the ones you could see through the wheel?
    If the caliper is a bit sticky you may well find that the inner pad is worn down more than the outer one.
    JSD 2.59
    Synergy-Solutions
    Stepho's Avatar
    Feb 2004
    Strathclyde
    444
    Quote Originally Posted by sidibear View Post
    Removed both front wheels and checked the inner and outer pads, both sets are OK, will check the fluid level as this is one I didn't think of.
    Sep 2011
    Worcs
    57
    You are not alone ! i've got the same issue .. some days it comes on with ignition , other days it randomly comes on mid drive somewhere. all pads checked .. levels checked too.
    Unfortunately it does not indicate on VCDS either so no chance of a quick locate.
    Stepho's Avatar
    Feb 2004
    Strathclyde
    444
    Thats how it started, but now its constantly on. Need to find a way of removing it as its a pain.
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    I have a vague recollection of a similar issue common on the B7. Think it had something to do with current from the battery. Will see if I can dig anything out.
    Chris
    Feb 2006
    derby uk
    39
    I had a problem with this on my B5, The battery was almost dead, would start the car but then I would get the brake warning light on for a couple of seconds. Get the battery checked, or leave it till the weather drops below zero and if its starting to go that will finish it off :-)
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Quote Originally Posted by Chris79 View Post
    Chris
    Yeah, I remember there was a guy a couple of years ago on here with it. A new battery fixed the issue.
    Try trawling back through the old posts.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
  1. Help - Brake Warning light on DIS
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2010, 13:50
  2. air bag light on and faulty brake light warning on dash ?
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th March 2010, 17:45
  3. Brake warning light
    By Dazz in forum General Technical / How To
    Last Post: 15th December 2009, 17:21
  4. Brake Pad Warning Light (NO DIS)
    By BigG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2009, 20:32
  5. Brake Warning Light After Brake Pad Change
    By iddyarmin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2006, 20:47
