Sky InsuranceAH Fabrications
    rockinred's Avatar
    Sep 2011
    9
    A4 56 plate 2.0 tdi 170sl Dpf removed/dele/remap/problem.
    hi guys hope someone here can help im strugging to make sense of it.
    ive got a A4 56 plate 2.0 tdi 170 s line
    ive had problems with dpf so went down the route of having it removed at www.torquetronix.co.uk with a company that works with them in stoke the guy seem to know his stuff but after the mapping was done he said it was fine i was happy no more limb mod
    i noticed the difference in the car but it was abit smokey but he said it need to just clear out the sht in the exhaust from when it was blocked and it would go after a couple of days, but i did mention that it needed a service so thought maybe that was causing the smoke.
    i had it serviced 2 weeks later and the mechanic did say that there was alot of blue/white smoke but couldnt find a problem with the car, when driving it comes out in waves and smells, and when idle warm or cold.
    can the map have been put on wrong i really stuggling to find what it is hope someone can help
    or had same problem
    from what i saw when the dpf was removed the guy took the drive shaft off to get to the dpf and took the dpf and hit out the comb of stuff inside then placed it back on and then remapped it but i was watching a he said took 2 attempts to get the map on cose didnt work the first time.
    rockinred's Avatar
    Sep 2011
    9
    going to see guy who mapped it hopefully its the map and nothing else causing it.
    Audi A4 avant 2.0 tdi sline 170 bhp 2006
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,313
    Why have you started two threads on the same subject?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Nov 2011
    hi did you sort smoking prob out, i have exactly the same problem on the same car if you could help at all??
  1. Audi A4 Tdi Sport Removed Compressor / Regassing Problem
    By samsam in forum Air Conditioning
    Last Post: 18th May 2011, 18:56
  2. Anyone had this problem? S3 8P 56 Plate...
    By gnic13 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2011, 16:37
  3. Air Con problem on S3 (2000 plate).
    By lloydsta101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2010, 15:36
  4. ECU Problem 58 Plate S3 Sportsback
    By jfairham in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2009, 16:44
  5. A4 2.5 Cab 55 plate problem with clutch
    By Blokeinpub in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th March 2007, 22:19
