EM TuningSky Insurance
Page 1 of 4 1234 LastLast
Results 1 to 40 of 125
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    DONE ! Retrofit Seat Exeo LED RNS E Media System into A4 B7
    Hi
    just thought i would share my experience of this mod.
    big thanks to Nathan ( Wrath ) who has helped throughout
    first i started with this;
    this is the concert ii double din unit
    this was a blessing as i did not have to buy any additonal harness or wires ( will go into this a bit later )
    i wanted RNS -E but the later spec LED screen version, so after much research i purchased a 2010 Seat Exeo Media unit ( this is exactly the same as the audi unit ) but has the much sought after LED screen.
    i got mine for £500 on ebay from a chap in Poland who does vag sat navs - i will pass on his user id if you pm me, many would be worried about buying from there, but it was sent UPS tracked and well wrapped.
    the seat unit;
    also i found the well laid out codes on top of the seat unit very usefull;
    so as a rough guide here goes;
    remove your unit using European stereo removal keys - push them in the slots and to the left ( left holes ) and right ( right holes )
    i had 2 keys so did one at a time.
    out pops the unit, now make note of the wiring diagram on the top of your unit - mine looked like this:
    i disconnected all the wires, the main one was the square block, this is done by squeezing the two tabs at the bottom together and lifting the arm on the back up and it come free as a whole.
    you are left with a square main block with 2 sub blocks - 1 black, 1 white
    now this goes just for my unit so others may differ
    i have Bose in my car so i needed to move pin B5 to pin B7
    push the tab on the block to take it out the block at the rear and you have it free of the main harness, then flick up the tab on the white block and you can access the pins NOTE THE PINS ARE NUMBERED IN EACH CORNER FOR REFERENCE
    I CANNOT STREES ENOUGH HOW VITAL IT IS TO MOVE THE RIGHT PIN - i didnt, i did it upside down at first and wondered why nothing was working lol
    anyway go by the numbers on the blocks and find pin B5 and put to pin B7, just push down on the pin and pull and i will come out
    if you look at my concert wiring diagram on the B section you can see the bose is 2nd in from the bottom left, make sure you get this right ! pin no 1 is bottom right put this to pin B7 which you can see if you refer to the seat unit is the pin that bose goes to.
    the next and even more vital pin is the K-Line, this is used for diagnostics and coding and stronger reception for FM radio stations so you MUST get this right or you will not be able to code this to your car !
    the K line is locate don block c ( black ) so do the same as per removal of above and move;
    PIN C7 to PIN B5 - this is the old pin that Bose went in so is easy to remember !
    K-line is identified as K-LTG on audi units
    its not the end of the world and you wont blow anything up, you will just be left with a half functioning unit, so try to get it right
    thats it, put the cases back on the blocks (black and white ) they ony go on their respective block so you cant go wrong and slot into the back of the large connector ready for putting into the back of the RNSE
    next up is to put your new sat nav ariel in place, this is easy !
    plug it into the blue port on the back of the unit and thread it behind the glove box, mine was magnetic and very strong so sits ok, i took my ipod glove box unit out to aid install - easy !
    now we are ready to plug in again !
    1 thing to note, i have an external phone system in my car so i had to wire that into the 32 pin av connector on the rear of the unit, this follows the same principle as above using;
    • Aux In (Left) - B1 to AV 22
    • Aux In (Right) - B7 to AV 6
    • Aux In (Ground) - B3 to AV 21
    this gets the phone working.
    so i plug it all in and it all fires up, now time to code it using VCDS
    first tell the car it now has navigation;
    i have ross tech so used their guide here;
    Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki
    i also activated the instrument cluster guidance and coded the steering wheel
    i have full SDS also now which is handy !
    here is the unit finished installed and yes the time is correct on the screen
    i get 7 satellites on reception, i have also changed a few other things, most notable the welcome screen from Seat to Audi using VCDS so it all matches
    i am happ to help with my experiences where i can but and not an expert
    so if i can do it, then so can you
    NOW FOR SALE
    Audi A4 Avant S-LINE 2.0 TDI
    BOSE - PARKING SENSORS front and rear - ANGEL REMAP to 183bhp
    LED NUMBER PLATE LIGHTS, HIDS, LED SIDE INDICATORS, LED SIDELIGHTS,19x9 BENTLEY'S, S4 345 MTEC Drilled/grooved Disks -35 on H&R SPRINGS, RS4 REAR ARB RS4 Grille FULL VCDS LED RNS-E DECTANE LED REAR LIGHTS
    TO DO:
    NOTHING - Am i finished really ??
    warren_S5's Avatar
    Oct 2007
    7,164
    Great change over, very OEM. Good write up
    Audi S5 3.0V6T Coupe Black Edition
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    iv fitted mine
    i had the chrome buttons swapped for black just cos i dont like them
    and to be honest its not worth the money my rns-e was just as good
    you get a better screen and bigger mem cards
    unless you have found anything else
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Not sure I follow
    This is the better screen led version as per later a3 and tt models and it does take 2 dd cards upto 32gb each
    NOW FOR SALE
    TO DO:
    bez101's Avatar
    Jul 2008
    8,492
    ok what i ment is for the price its not much better than the older rns-e
    all you get extra is the led and you can use 32gb cards
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    the screen is far superior to the older rns-e
    i paid £500 for it, the older rnse are about £400 - £450 on ebay
    so for the extra its well worth it imo
    and it came with a 2011 navigation disk
    NOW FOR SALE
    TO DO:
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    pic in the light of day
    NOW FOR SALE
    TO DO:
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Hey Doug, welcome to the club (sort of)
    Really impressed it all worked out and that you already had double-DIN!!!!
    Once you have one you know you wouldn't go back. The screen and the acceptance of SDHC cards are fantastic, I wonder if the sound processor is any better, who knows?
    Anyway, nice to see the pics.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    I would say the music sounds better.
    But I would say that !
    But .......
    Even the missus said it sounds better so there must be something in it.
    Just driven from Rochester to Southampton. And I am really impressed with the nav function on it
    Clear and in plenty of time
    A wort while mod for sure
    NOW FOR SALE
    TO DO:
    bez101's Avatar
    Jul 2008
    8,492
    ill agree on the sound quality
    but the lack of full post code is crap
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Have they still not changed that?? That's the worse thing about the Nav by a long way. A £50 bagain basement satnav accepts a full postcode!!!
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    bez101's Avatar
    Jul 2008
    8,492
    nope no full postcode search for a new model
    thats the 1st thing they should have done
    i still have to carry a tomtom just in case
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Me to!! Kind of defeats the object though, doesn't it.
    RNS-E retrofitted
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Interesting video where someone appears o have enabled full post code:
    Full UK Postcode Lookup - YouTube
    Nathan
    Jan 2011
    82
    I want 1.... been offered and rns-e for £450 but i think thats expensive looking on ebay. Also worried that for the same money tho I could have an aftermarket dvd player, sat nav, bluetooth hands free, ipod cd radio etc...... are there any aftermarket ones out there that use the steering wheel controls and use the bose??
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Bez - mine has nit got the chrome volume and nav wheel, don't suppose you want to send me yours ????
    NOW FOR SALE
    TO DO:
    bez101's Avatar
    Jul 2008
    8,492
    i put it on the old rnse and sold it like that
    but other reason i didnt have it is i didnt realy like it and also
    twokers see the chrome and know its the new 1
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Quote Originally Posted by Wrath View Post
    I need that
    Information about navPOInt - custom POIs for your Audi SatNav
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Yes I looked at this also. It said coming July 2011 but there is nothing out there at the moment
    NOW FOR SALE
    TO DO:
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    i would happily pay for that if it worked/is ever released....
    i like RNSE and only downside is not being able to put in full postcodes
    2009 A4 Cab B7 2.0 TFSI S-Line Special 'Final' Edition
    Phantom Black - Black RS4 Wheels - Black Leather
    RNSE MMI, B/tooth phone, Bose, RS4 pedals, Bi-Xenon, LED number plate lights..
    Wants - electric folding mirrors, ambient lighting, puddle lights, rain sensor, auto lights, auto dim rear-view..
    Nov 2003
    London (N8)
    515
    Quote Originally Posted by doug.p View Post
    Yeah there is... check the downloads section.
    It seems to be a re-written OS version which utilises data from other GPS map sources.
    bez101's Avatar
    Jul 2008
    8,492
    Quote Originally Posted by ultramodz View Post
    have you got a link ?
    Nov 2003
    London (N8)
    515
    Posted above dude, but here's the link to the exact page for you
    Download navPOInt - custom POIs for your Audi SatNav
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    that only adds poi's not full postcode search :-(
    NOW FOR SALE
    TO DO:
    bez101's Avatar
    Jul 2008
    8,492
    yep the pois wont work like on the tomtom etc
    so not realy worth the mess about
    id love the full Postcode tho
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,244
    Unbelievably annoying that it doesnt do full postcode, always have to ask people for postcode and street...schoolboy error by Audi, don't know what they were thinking...nobs
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
  28. #27
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    I have a 2010 RNS-E unit from the later A3/S3....High Def screen although I dont thinks its LED? I think someones confusing the RNS with the VW 510 nav units...... it also has full post code enabled, media button etc but with the silver buttons unlike the above unit.....(i think the silver buttons make it look much more modern!)
    Curious why you have gone for the SEAT unit......
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
  29. #28
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Quote Originally Posted by 1animal1 View Post
    He's gone for the Seat unit to avoid having to change over the faceplate (finding one is difficult enough). It's essentially the same unit. I have a 2010 A3 unit and I don't have full post code so am interested how yours does. It must have been updated.
    Nathan
  30. #29
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    ^^^^^ what he said ^^^^^
    Maybe take a pic of your unit and pist here and to my knowledge the later a3 had the same unit as mine, they are all rnse, if it has the Media button it's the later version. Have you modded your unit somehow ?? Very interested in your response.
    As a side note, my unit has full poi and speed camera locations, I also get sat nav directions in the dis, I have now filled a sd card with 10 albums I get full access and full album and track names - very impressed. Cranked it up today and with the Bose it sounds very good indeed
    NOW FOR SALE
    TO DO:
  31. #30
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Doug I have older version in 09 car but I also have directions in DIS display FYI,
  32. #31
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Yeah I know some have it, but I have read that after retrofits some people are having to turn the unit iff and on again after the route is input, mine worked straightaway - I have no idea why.
    When navinis in the dis, the vwrh bottom sat 4 pixel colums are empty, I have seen cars with auto transmission this part of the display has p d n etc just wondered if anything else should be in here ?
    NOW FOR SALE
    TO DO:
  33. #32
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Doug, does he track name scroll in your DIS or does it just show so many characters of the track name? I did see a torrent download for the old unit where the track name was scrollable in the DIS.
    Nathan
  34. #33
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Doesn't scroll, but my track names are fully displayed, you can also click an option to display all info on the playing now track.
    Scrolling names sound good
    NOW FOR SALE
    TO DO:
  35. #34
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    Just re read, in the dis , no not full track names at all , only the first few that it can display
    Maybe a vcds thing ???? Can sort
    NOW FOR SALE
    TO DO:
  36. #35
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Same here just first few letters of track name in dis
  37. #36
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    mine doesnt have camera locations, but im pretty certain it has voice control activated too which is RNS-E model specific i understand..... mine is the one just before the black gloss unit came out..... I could take a pic but it won't show you anything other than the media button?
  38. #37
    Jan 2004
    York
    1,657
    SDS can be set on any release of rns-e. You just have to install the correct "hacked" firmware.
    MY15 8V S3 Sportback with options
  39. #38
    doug.p's Avatar
    Getting There
    Rochester, Kent
    294
    1animal1
    so yours definatly has full uk postcode entry though??? if so it came like that or did you do something to activate it
    NOW FOR SALE
    TO DO:
  40. #39
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    Doug... I haven't done anything but code it to the car.... full post code
  41. #40
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    That is weird, what SW and HW versions are you running?
    Nathan
