Badger5Chris Nott
Results 1 to 15 of 15
    Aug 2011
    10
    Retrofit Armrest HELP
    hi guys, i know this has been mentioned b4 but cud sum1 pls advise me.
    I bought a genuine armrest off ebay to fit my a4 b7, but it was missing the bracket and nut so ordered this frm cdf audi. Had all the parts ready and didnt want to attempt fitting it myself so had a local garage who specialise in audi/vw to do the job for me.
    They told me to fit the armrest they would need the car for 1 hr but that time turned to 6hrs once they started???. Also the guy said in order to fit it they would need to remove the whole centre console & so the glovebox must be removed along with aircon controls & my headunit (navunit). Also mentioned abt removing front seats??? Surely cant be this hard just to fit the armrest as iv not seen any1 else mention this on here b4? Anyway got the car back (all put back tidy apart the mess of empty packaging) and guess wot? The hole that was cut to slot armrest in is too big. Iv got a nice big rectangular hole surrounding the armrest! Obviously theyve made a cock up rite? Whn questioned they claim thats the only way it would fit thats why the hole had to be cut so big. It looks as tho my 7 year old daughter has had a go at it. Looks a mess...................
    Any suggestions?
    thanks.
    alpesh26's Avatar
    Mar 2011
    271
    Theyve definately screwed that up! Does the cowling for the armrest bracket not cover the hole?
    I fit my armrest on monday, took me about 1 hour to do it, didnt even need to remove the centre console. All i took out was the front and rear ashtray, the velvet mat thing, and the cover in the hand brake recess.
    Got any pics of the damage?
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Aug 2011
    10
    No the cowling does not cover it. Theres a gap rite around it and its even bigger on the right hand side, worst thing the cut is all jaggered and looks nasty, wudnt be too bad if it were covered up. Well iv been screwed over then by da sounds of it? Aint paid them yet!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    right you need a new consol
    if you had asked the forum 1 of us would have sent you the template
    all you do if remove rear ashtray
    use template cut hole
    unbolt 1 bolt
    slip armrest in and refit the bolts
    job done i can have them in in half hour
    god knows how they ****ed up if they removed the center its outlined on the back where in needs cutting
    i hope you didnt pay
    bez101's Avatar
    Jul 2008
    8,530
    Quote Originally Posted by Taz1 View Post
    take a few good pics also i may beable to point u to some good black gasket that will make it look good
    also did you use the oem rubber gasket ?
    Aug 2011
    10
    got a bad habit of rushing into things
    they asked for £££ but i looked at the job & said looks like u owe me cz of the poor job!
    Well this all sounds so easy i cud av done it. How they say they had to strip out nearly half the car i dont know? God knows wot they were doing for 6 hrs???
    Just to confirm this is a a4 b7 on a 2007 & its got a standard centre console. So should be same as every1 else yes?
    bez101's Avatar
    Jul 2008
    8,530
    yes b6 b7 all the same
    id get a new consol around 30 quid from ebay
    Aug 2011
    10
    il try & get some pics up whn i can. I didnt knw you can get the blk rubber. any part numbers? ta
    alpesh26's Avatar
    Mar 2011
    271
    Might just be worth getting a console with an armrest hole cut in it. I got my armrest from a breakers yard in chorley, preston and the car it came out from still had the centre console in it. I'll try and dig out the the number for you if it's any good for you?
    What's this about a gasket? Didn't fit one on mine :S
    bez101's Avatar
    Jul 2008
    8,530
    bottom of armrest has a thin rubber gasket round it
    alpesh26's Avatar
    Mar 2011
    271
    Hmm i haven't got one of those. Know where I can get one from/use as a substitute?
    bez101's Avatar
    Jul 2008
    8,530
    audi dealers
    Aug 2011
    10
    audi dealers
    thanks for all the info guys. Any1 got the p/n for this gasket thn?
    2,180
    As you have satnav you will have a double din console, which can be difficult to get from eBay, you can cut a single din console to fit a double din head unit & climate control. On the arm rest side the garage made a complete mess of this one. You do no have to remove the centre console to fit the armrest, a simple dremel and a socket set with a 13mm socket are the only tools required.
    Nov 2011
    Hi
    Does anyone know where I will be able to get a copy of the template for the hole possition ? as due to finacial constrants I will have to get an arm rest second hand from ebay rather than a new one from Audi
    cheers Ian
