Chris NottJMB Retrofits
Results 1 to 7 of 7
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    3.2fsi Ecu Version???
    Does anyone know the 3.2fsi ecu version off hand?? Im looking at getting it remapped and theres been a couple of hiccups pairing it. And they think it will be easier to work out if they knew the ecu version to see if any other models are the same.
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    If you look on emaps website and find your model, it tells you the ecu model
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    rizzini7's Avatar
    Jun 2011
    728
    Cant see the 3.2 on there. Unless the A6 uses the same ecu
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    i wouldnt bother on the non turbo engine
    for the cost anyway
    rizzini7's Avatar
    Jun 2011
    728
    Want a remap to smooth it out more rather than gain masses of bhp. Had a qoute of £249 if it can be done and i like the gains or will remove and charge nothing so thought its worth a look. Also got it priced up for cat-back exhaust removing the centre box and replacing the other 4 with high flow ones
    He wanted to know the ecu version in order to access it
    bez101's Avatar
    Jul 2008
    8,492
    not been funny but if hes a good tuner he should fint that out himself
    id be looking for someone that knows what there doing
    rizzini7's Avatar
    Jun 2011
    728
    I know where youre coming from. Its just ive tried a couple of remapper locally and theyve not been able to communicate with the ecu.. And alot of sites and mobile mappers in my area dont list the 3.2 a4 or if they do you have to send the ecu away. The most recent guy said if we could find out the Ecu version beforehand he'd get all the info before i travel to him. Rather than just turning up and finding he cant read it
