Volks AutosSky Insurance
Results 1 to 19 of 19
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    VCDS is there a definitive guide.( i need a bit of help)
    I finally bit the bullet and today i received a new vcds cable off nigel nhn as i need to do some coding to my car which i need help with.
    I'm fully aware of the damage you can do if you change codes without knowing what your doing hence why i'm here annoying you lot
    Is there a how to guide on here (i can't find one) i have read most of ross tech's site .
    Any way here are the two issues i need to sort.
    1)Last year i had full oem bluetooth fitted by another site member all worked perfect including dis and MFSW , after a week or two i began to get alot of static through the bluetooth so i took it back, after many hours of scratching heads and trying different things we determined that the unit was faulty , so i took just the bluetooth unit out and sent it back leaving all the wiring in place, they confirmed it was faulty and sent me a new one a few days later
    So new one arrives and i fit it as in just plugged it in , it works perfect as in i can make and receive calls the radio goes quiet ect, but the DIS & MFSW do not work as it did before , did it lose the code do i have to recode and if so how .
    2)Problem 2 another member off another forum (A8 tech) a master tech for audi fitted my cruise control last year and during fitting i told him i was going to be having a fiscon unit fitted at a later date so while he was coding the cruise control he coded for the fiscon resulting in me losing all radio/headunit info from the dis , i never had the fiscon fitted in the end i left it as stock .
    I need to recode for the concertII to the DIS as above how do i .
    Sorry for the long post but if anyone could help it would be greatly appreciated .
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    27,126
    Whats your current coding for the radio 56, instruments 17, steering wheel 16, telephone 77?
    If A8Tech did your car, then he did everything properly given his knowledge, so maybe somethings just amiss from the issues you've had.
    When you enter a module, it does popup what coding is available for each module, so it has its own built in helper.
    RT do have a manual online at this link:
    Ross-Tech: VCDS Tour
    Best way to learn is to familiarise yourself with the interface & how to enter coding, etc, but always make a note of where you were, what the coding was before, etc so if any issues, you can refer back to this to correct the issue.
    Edit: Removed gateway advice info, whoops 8P head mode :P
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Thanks for that Nigel, I wasn't trying to undermine jon's skills in any way he is a top fella he was doing it as a favour ,I have been trying to get up to him for best part of a year as he was going to do this coding for me but he is 100miles away and my work got n the way most of the time , that's why I ended up getting the cable off you.
    I've not connected it up yet but I defiantly make a note of the codes in there now, thanks for the tip and link.
    F
    2,180
    B7's don't have can-gateway 19, just incase you get worried no communication messages.
    27,126
    Yes sorry was in 8P mode, forgot we were on about a B7, instruments 17 controls whats on the gateway bus lists, I've edited my post
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    here are a few picture of existing coding , if anyone can help .
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
    F
    27,126
    On 1st check as little busy, the BT module isnt even coded mate, code that 1st then see whats happening.
    I'll have another look when got bit more time mate, sorry.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Well bloody hell, 1st attempt at coding the bluetooth nigel and it all works dis & mfsw . Fantastic thanks just the head unit info in the dis now.
    F
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Well done mate.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    To get the concert II in the dis(only) working will the coding for this be under radio channel 56 or instruments channel 17.
    Thanks gary i think it was beginners luck
    F
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Still looking for help with above mentioned, also what's the difference between these two in the drop down code helper
    Example
    > 1 = xyz
    >+1 = xyz
    notice the plus sign does mean you add 1 to the code already installed.
    F
    27,126
    Try checking the BUS devices coded onto the instruments, go into instruments then adaptations & you should see down the list the BUS options & see if radio is actually enabled on the relevant bus, as tbh most default show dis info for the radio, atm my minds fried from many things today so may have missed a note here, but thats a good start.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    sorry nigel i know i'm driving you nuts , but this one had me stumped.i think i understand part of what you said , here is the drop down list in 17 instruments - adaptations
    thanks .
    F
    27,126
    Try coding that as 19 & see if that then shows DIS info.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Nigel i think you are my new best friend that worked spot on,finally a year on and all is working as it should .
    One day when you less busy i would love to know how and where you got that code from .
    Thank you .
    F
    27,126
    Easy, check what adds upto 19 in that list of numbers, 16, 2 & 1 = 19
    Basically you have those 3 systems those numbers represent.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    i think the penny has just dropped, my god easy when you know how.
    I think i need some practice
    F
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Shame the b7 doesn't support long coding,
    How do I code for windows up/down with the remote as the cab is different.
    Also coming home lights , I know 1wheelony has this on his b6 cab I don't care if they come on in the day too.
    F
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Anyone kmow if this will work on the b7.
    http://audiretrofit.quinlivan.net/cominghomelights
    A
    lso how do i code for window closure of the key remote , works on saloon but coding is different on the cab .
