Sky InsuranceChris Nott
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Traction control light
    I've just fitted cruise and DIS, i havent had time to get it coded yet though. The traction control light is permanently on now, is this normal? Will it disappear when the cruise and DIS are coded? It went off for about 8 seconds when i took it out for a spin but as soon as i braked, it came back on.
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    807
    Yeah i wouldnt worry .. Im sure mine was on too until i coded and recalibrated (basic setting) on the steering wheel.
    AFAIK the ESP relies on the steering wheel angle sensor which gets skewed when the wheel comes off. therefore its giving an incorrect signal so it disables ESP.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Just to update, after the car stood for an hour the light went off next time i drove it. Result.
    Just ordered the the washer bottle sensor from Derby stealer, for the DIS - £7.88. The parts bloke first reaction was "you can't buy them, its part of the bottle", he changed his mind when i gave him the part number!!! Trained monkeys!!
    RNS-E retrofitted
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    653
    You got the washer sensor and stalk part numbers mate??
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
