Chris NottBadger5
Results 1 to 7 of 7
    Apr 2008
    Swapping roof on a cab
    HI all,
    I wonder if anyone can give me any pointers on how easy (or difficult) it is to swap a roof on a 2007 A4 cab?
    I fancy changing the standard black one for a different colour but before I go buying one I thought I better find out how difficult the actual swap is.
    Anyone able to help with any instructions / costs etc?
    2,163
    From reading elsawin if your good with the spanners then you should be OK, however you need a specical tool (VAG tool number VAG1742) to align the windows to the new roof. Some times you can get away without these tools, but they make like a hell of a lot easier with them!
    Found this cut & paste out of elsawin.
    Convertible Top Overview
    Apr 2008
    Thanks very much, might have a go at this myself if I can't get a decent price for someone else to do it.
    Apr 2008
    Just had a quote from Audi - 8 hours labour!!! Might have to call that idea off as a bad plan.
    2,163
    Try an independent, it looks a good few hours work, but don't think it's 8 from read the instructions.
    Apr 2008
    Thanks, I will look up a few Independents in the area. I did think 8 hours seemed a bit excessive
    davidfox280585's Avatar
    Aug 2009
    108
    Quote Originally Posted by Gizmo750 View Post
    i fitted mine myself infact ive done 2 now,there pretty straight forward,
    storage cover box off,
    osr boot liner out,
    lower rear bench off
    both rear quarter cards,
    boot lift up panel out,
    mostly unclip wiring leaving pump attached with hydraulic cables,
    3 bolts per side 1 bolt is a locator bolt for refitting to take the weight need any info just ask
