JMB RetrofitsAH Fabrications
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Anyone tell me if this is right?
    Dudes, im looking to go lower on the rear with my coilovers, there is a rubber mount underneath the rear springs which is where you adjusters normally go (my adjusters are on top of the spring)
    Anyone whos fit coilovers or seen there standard setup, can you tell me if i need this rubber bush at the bottom or if the spring will sit ok just on the metal platform?
    Bottom of the spring:
    Top of spring:
    Thanks.
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Mine had the spring perch at the bottom, though I'm not sure it makes much difference as long as it's all secure?
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    RS4 grill | S4 mirrors | Tints: 45% sides, 35% rear screen | EasyStreet AutoPilot + AirLift struts/bags | Touareg ET60 9x19" on 215/35/19 all round | 25mm front, 35mm PCD adapters | EBC Red Stuff pads | Red calipers | RS4 pedals | Late-spec clear corner OEM bi-xenons | Leon Cupra R splitter | RNS-E | Ambient lighting | R8 oil cap | Carbonio & more
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Do you think i would be ok to leave the adjuster on top and remove the rubber perch from underneath? im not sure if it will sit securly enough?
    Thanks.
    unikarl's Avatar
    Mar 2004
    374
    If the rubber is removed the chances are you will get a bit of noise from the spring. I had an issue with a mk4 golf I had and it turned out to be a missing piece of rubber.
    2.0 TDI S line.
    Cruise, Leather, DIS, RNS-E, autodim, MFSW, ambient lights, Bi xenons.
    Gone to its new home
