AH FabricationsChris Nott
Results 1 to 12 of 12
    Aug 2011
    13
    Daytime running lights
    My S4 Avant (06) has daytime lights (only just realised after 2 weeks) but I would like to fit the LED style ones on the newer Audi's.
    I know there are various kits on the market, can you get inside the headlight to fix the LED's and use the same wiring loam?
    R33P.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    You would need to bake your lights in the oven to melt the glue so you can remove the glass as they are a sealed unit , I know of a few members on here and other forums who have done this.
    You can get ones already converted which look good , there are lots of threads on here about this including where to buy the better quality ones from .
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    You can go to Audizine forum and find a guy called Fly3000k who takes your headlight and makes them but there roughly £300 and you'd probably be best buying 2 spare headlights off ebay and sending them, if not he might be able to sort something out for you but this is no cheap or easy mod. unless preppared to spend a fair bit i'd probably just forget about it.
    or you could have them fitted to your fog surrounds like mine?
    Much cheaper.
    Mafia black 2007 A4 S-line 2.0Tdi - RNSE - Bluetooth - MFSW - GSM phone prep - Privacy glass all round - Cupra R splitter - Black Grill, surround and fog surrounds - 12" sub and 1200 watt JBL Amp - AP Coilovers - 19" RS6 Alloys - 6mm f & 15mm r spacers - Carbon wrapped interior - Blue LED dials - Ambient Lighting - Cruise Control - HID's - LED side lights - mapped to 185bhp / 380nm - Twin exit exhaust - RS6 style DRLs
    Aug 2011
    13
    Fog surrounds sound a good idea, how does that work mate?
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Where you based? I know a guy that can do them for you way cheaper than the headlights job, basically you drill little holes into the fog surrounds and insert LEDs then seal them.
    check out my build thread for a picture.
    Aug 2011
    13
    Hi mate, sorry please can you explain "check out my build thread for a picture", I only joined the forum today.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Ok mate, go to the build threads section which is a bit below our B7 section and mine should be near the top and titled A4 s-line low and slow
    Aug 2011
    13
    Looks sound, give me a good idea now, cheers for your help.
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Alternatively, you can replace the lamps with LED versions and get pretty good results - make sure you get can bus friendly ones though!
    Does the S4 have the same foglight surrounds as the standards S Line?
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Triple.O.G's Avatar
    Jun 2010
    Leeds
    1,125
    Nice one mate, let us know.
    Yeah dub they are the same!
    Jan 2004
    York
    1,641
    If you have drls, you have xenons. I wouldn't be messing with them if it were me. Dammed expensive to replace if you feckup splitting the lens from the housing.
    8V S3 Sportback with options on order
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    There's a few grill options you can consider here:
    For those thinking of DRL's or Fog Grill Mods - here's some I tried earlier!
